Grex random sander
Grex random sander
Grex random sander
eliot d
>I have one of these sanders. I have a modest air compressor( not the really small pancake kind), something like 4 cpf at 90 psi (max 135 psi), that I use with it. The problem is that the Grex spins like crazy and immediately sets off the air compressor, so that it more or less runs constantly. I thought I saw a post here that there is some kind of adjustment to slow it down. I did find a brass screw on the side, but turning it didn't seem to do anything. I could use some advice.
Re: Grex random sander
Re: Grex random sander *LINK*
Juergen
>Go to the link below for a cheap solution. Now the long answer. your compressor probably already has a regulator which can be set to a lower PSI hence slower operating speed. If I remember correctly the speed can be controlled with trigger pressure.
If you use pneumatic tools frequently you should consider an air/water separator, oiler, and inline filter to prevent damage to your tools; especially working in a dusty environment. I checked with Grex and they recommend running the tool between 80-90 PSI and the sander consumes air at 6 CFM. For your information the sander will free wheel nicely. I usually let it free wheel if the compressor is getting hot to let it cool.
Cheap Regulator
Doug Thompson near Cleveland
>The adjustment is on top of the grip, run the screw in until the speed is what you need. I seem to remember quite a few turns but then again I do suffer from CRS.
Re: CRS
adrien
>I hate acronyms. Have to look them up.
Assume this stands for either
cranio-rectal syndrome or
Can't remember s..t
eliot d
>I must be missing something; the link shows a swivel connector. How would that regulate the speed of the Grex?
LoL... both I can't remember.
>They do sell one with a regulator. The swivel connector will leak air but if you disconnect hose everytime it really doen't matter. Slow it down with the adjustment on the grip.
Juergen
>They make 2 version with and without regulator. To save money they probably used the same picture. I think the larger point is if you dont want to damage your $100 tool get a separator/Oiler which should also includes a regulator.
