Follow up t CD glueing question
Don Henthorn
>After the post yesterday in which I exposed how far my memory has deteriorated I guess I may as well continue. I did know that epoxy wouldn't take on plastic because I used to use the little plastic jello cups to mix up my epoxy in BECAUSE it would pop right out after it dried and I could reuse the cup. I just forgot that CD's were nothing but plastic. DUH!!!! Anyway I deserve a D for trying. My next question is: can I use cyanocrilic(sp) glue for the disks and the wood skins?
Re: Follow up t CD glueing question
Eddie Pacheco, San Jose, Ca.
>Hi Don,
You had your first posting about this on the flatside. I think that ca glue on the CD disks and wood won't last for long in a windchime application. Is there a way that you could pin through your walnut top and bottom sandwich pieces, with wood dowell pins. Drilling for these at initial CD disk and wood assembly, and then final turning afterward?
Thanks, Eddie.
Don Henthorn
>I could pin them but I guess I will try something else.. Wood will do but I need a harder and heavier wood than walnut or bay berry which are all I have at the moment.
Doug Turner
>I believe polyurethane glue (gorilla glue) will glue wood to plastic. You might read the label and then experiment for you application.
