Coolibah Burl
Mike Cunningham (Cape May NJ)
>Coolibah burl natural edge bowl. 17" overall with 9" bowl area, height 3" Sanded through 600. 3 coats Watco and Beall buffed.
Thanks for looking
Mike
Coolibah Burl
Thanks for looking
Mike
Re: Coolibah Burl
Ruth Niles
>Cool, Mike, I really like this. Is the color as red as it appears? It's beautiful.
Re: Coolibah Burl
>Thank you Ruth. Yes, several shades of red as well as some near yellow. The stuff is hard as concrete, numerous trips to the grinder.
Thanks again
Mike
Re: Coolibah Burl
Tommy Holmes
>Beautiful piece Mike. Did you do anything to the bottom? I have just bought a blank like this (smaller) recently from Woodturningz and didn't quite know what to do with the bottom. It is covered with with a heavy coat of wax.
Re: Coolibah Burl
>Tommy,
I turned the bottom as you would with any bowl. This was a burl cap. I mounted it smooth side with a face plate and turned the bottom (this side had the points or eyes) leaving it a bit thick to allow flattening and turning of the top. Finished the bottom and then turned it around and hollowed out the bowl and turned down the wing areas. When finished I actually put it back on the lathe holding it with a vacuum chuck to touch up a few spots on the bottom, though normally it would have been done at this point. In this photo you can see the bottom though I admit it's a poor photo, in the center are the usual "rings" that I and many use to finish it off.
Hope this helps
Mike
Re: Coolibah Burl
Tommy Holmes
>Thanks for the picture of the bottom and explanation of how you turned it. This is one more step towards working up the courage to try mine.
Re: Coolibah Burl *LINK*
>Tommy,
No problem, they're easy to do, just give it some thought and take your time. Some of these burls, particularly the Australian, at least in my opinion are quite hard, contain silica and take a toll on tool edges. Keep the tool sharp, you can't make too many trips to the grinder!
I buy my Aussie burls from LeeTreeworks. Hit the link for a tutorial on turning caps, I think it will help you.
Re: Coolibah Burl
Bob Fawcett
>Very nice wood.
I may have to try one of these someday.
Thanks for the link also.
Looks like you have been busy, unlike me who has been busy with too darn much work.
Re: Coolibah Burl
Tommy Holmes
>Mike, this link is just what I needed. I will be turning a burl cap shortly. I really appreciate the information.
