Woodchucker sandpaper
eliot d
>I doubt that it's really called ,'Woodchucker', but it's from a Canadian site called something like, 'woodchucker.com' where you get it. Does anyone use it? I do, and I like it very much. But I have a question: when you look at it up close, it appears to have a very regular, kind of rectangular grid pattern to it. It doesn't look like tiny particles, for example. Does anyone know how this stuff is made?
Re: Woodchucker sandpaper
Bill Howatt
>Woodchuckers is great but their website is not the best. Is the paper you are referring to Astra Microdot? It is good alright and it was highly recommended to me by various turners.
Bill
eliot d
>Yes, that's it. (Or is is Astrodot?) I looked again, though, this time with a magnifying loop, and , for the lower grits there are, indeed, grains of some kind of abrasive there. Small clusters of them are arranged repeatedly in a regular grid pattern. I had in mind that someone had figured a way to somehow etch cutting lines in the material, and I thought that was a real breakthrough. Thants not it though. Getting small clusters of grains to line up in a grid pattern is quite a trick too, I would guess. Apparently, such an approach leaves a lot of space around the grains so the sanding dust will clear. And sure enough, after you use it, if you just blow compressed air at it, it cleans instantly.
George Van
>The AstroDot sandpaper has the grit electrostatically positioned. You can really see the pattern on the 80 grit. It looks like it would leave a lot of scratches, but it does not. Bill Neddow told me to try it, it lasts a long time and does seem to have a very strong backing.
