Relocating power switch on my Nova 3000
Steven Antonucci
steve antonucci
>Which option would you pursue if you wanted to move the switch to another location? The idea is to have it repositionable without reaching to the motor.
1.) Add a remote controlled switch box and a remote? (I think this are possible?)
2.) Just extend the wiring to the existing switch and relocate the box with a super magnet?
3.) Same as 2 but change to a push pull button?
(I'm leaning towards #3, since I hate the button on the existing motor and hate reaching across spinning work...)
Any comments, hints or pictures welcomed...
Steve
Re: Relocating power switch on my Nova 3000
Jorge Castaneda
>Hi Steve,
Here in the local High Schhool, the shop teacher put in all the lathes a knee activated bar switch as wide as the lathe is, no need to reach over a spining whatever, he also rigged the variable speed controls to no start unless they are in zero.
Food for thought, I should start thinking the same, I do not like having to reach over the spinning work.
Jorge
Bill Howatt
>I relocated my on/off switches and speed control pot for my General 260. I have it on a long cable and I can put it on the bed or anywhere else I want. It normally is on the bed. I have a pushbutton on the other side of the headstock which turns the lathe off only.
I put the speed pot in the box beside the on button so I could see where the control was set when going to push the on button. My way of thinking says that having an On button remote from any speed control is a potential hazard.
Having to reach in front of a spinning bowl blank to turn the machine on/off or to adjust the speed is bad design but not uncommon design.
Bill
Jim Swank
>Extending the switch is the easiest. This would also be a good time to change the switch so you had reverse available, or you could put a fwd-reverse switch on the motor and make the on-off remote. All sorts of possibilities.
Jim Pugh, Elyria, OH
>Steve, a multi-outlet strip would be quick and easy either as a temporary or permanent fix. Locate it on the right leg or position of your choice. Plug it into the power supply and plug the lathe into the strip. Use the circuit breaker switch as your on-off switch. Also provides places to plug in your power sander or other tools.
Ed Heuslein
>Howdy Steve: I have a Nova-3000, variable speed with reverse. I installed an on/off switch which runs to the tailstock end of the lathe (I also have a bed extension).
I used a regular household light switch - commercial duty (electrical store, not one of the big box stores)which costs less than $5. Install it in a plastic box. I glued two rare earth magnets (1") to the back. I used #14 extension cord cable to the existing controller. Remove one of the wires from the existing switch. Connect the new cable, one wire to the switch, and one to the wire you removed.
Both of the switches must be on for the lathe to run. Either one turned off turns the lathe off.
It's easy, and it works. It also maintains your soft start/stop functions that wouldn't happen if you just put a switch in the AC power line.
Good luck.
Ed
Steven Antonucci
Thanks to all
steve antonucci
>I know what I need to do, and now I just need to do it.
Steve
Re: Would it work on a Oneway?
Allen Neighbors
>Could it be done on a Oneway 1640 that has the Control Pedestal? I know that Oneway sells a remote switch, but I made one for my old Grizzly just like the one you describe, Ed, and I wonder if I went into the controls and connected to the switch power leg, would it interfere with the speed control or the decelleration switch? I really don't see where it would.
Ed Heuslein
>Howdy Alan: I have never done it to a Oneway but have done it to my PM-3520. The key here is to make sure you are running the new switch/cable to the "run/stop" switch, not the "on/off" power switch. I assume Oneway has such an animal.
I also have a Jet Mini-lathe that I've added an auxillary switch to. In this case, there is no run/stop switch so I ran it to the on/off switch which is in a direct line with the cord that plugs into the wall. I just use this as an emergency switch however. I've done the same thing to Deltas that have 110V AC motors, not to be used for normal start/stop functions, but as an emergency kill switch so one doesn't have to reach over an "out of control" piece of $100 Pink Ivory (or in my case, a piece of hackberry!). Hope this helps. Ed
