ADVERTISE HERE - FREE TRIAL
Hollowing Laser Holder
Mark Kauder, Phenix City, AL
>I want to make a holder for the micro adjustable laser head I bought from Don Derry, to put on my Jamieson
What I am looking for is opinions on ready made holders or pics of homemade ones that work and are not too wobbly.
Mark
Re: Hollowing Laser Holder
Allen Neighbors
>Mark, I just made a new one this evening. I got tired of mine wobbling, and the light flickering on and off. The new one I made is pretty heavy, and looks like crap, but for a prototype, it works like a charm. I'll use lighter wood, and smaller bolts and make another one one of these days, but I'm going to stick with my model. Steady as a rock, and the light stays on.
I'll get a pic of it later, and post it for you.
Bob Moffett
Bob Moffett
>There is an article in the Spring 2003 American Woodturner magazine about how to make one. It uses square aluminum tubing so it appears pretty stable. I am working on making one as soon as I get all the parts.
Sean Troy
>http://woodturningtools.net/v-web/productpage/images/Laser%20Block.jpg
This is the one I use. Sean
Re: On second thought, Mark,
Allen Neighbors
>I'm not going to photograph that piece of junk I made. I'm going to make one of these!!! :o)
Thanks, Sean, for posting this pic!!! :o)
I've made two of those slightly modified of course
Al Crandall (N.E. of Indy)
>I really like the 3/4" square aluminum tubing for the arm. I have a short one for the mini lathe set up and one for the big lathe which will extend 20" past the tool rest. I use this last one for the 1" boring bar. It is too short for the 1 1/2" boring bar, but then I haven't needed the 1 1/2" bar yet. I'll cross that bridge when I come to it.
Re: I've made two of those slightly modified of co
>Al,
You are the engineering type. Which would be stiffer 3/4" aluminum or 1/2" steel - both square tubing with about the same wall thickness. I happen to have enough 1/2" steel, but can certainly pick up the aluminum.
Thanks
Mark
>Bob,
Thanks, I found my copy right away. Looks like just the ticket, though I will keep my eyes open for others.
Thanks,
Mark
>Thanks, Troy.
I already have the laser holder/adjuster. I do like John Lea's work. Saw his tools at that meeting out in Tempe 4-5 years ago when we first met.
Mark
>Here is the Don Derry laser and adjuster. It is pricy - around $100, but a first class laser, and a great fine adjustment on two planes.
Mark
Re: The modulus of elasticity of the two materials
>Just kidding; I have no idea which is stiffer. But I have had great success with the 3/4" aluminum from the home center and plan to stick with it. My last laser holder is on a rig which uses 1" boring bars and is really steady when extended to about 18" past the lathe tool rest. I made a 1 1/2" boring bar for depths of 24", but as yet have not tested it. The laser support bar won't reach that far anyway. There might be a small amount of vibration during aggressive roughing, but when it comes time to hit the mark for final wall thickness the unit is rock solid. Another thing I change on my lasers is to mask the end of the laser and punch a small hole in the mask. I find the "as purchased" elongated laser dot to be anoying to set up accurately. The new smaller round dot is easier to set up and more accurate when in use.
>Thanks, Al
Mark
Re: Hollowing Laser Holder - Thank you All
Re: Mark, here's the one I made today.
Allen Neighbors
>That should work.
Mark
>This is mine. Pointer is held by 2 small grub screws and the switch is the thumbscrew.
Captured Hollowing has a new Convert - long
>First off, thank you to Bob Moffett for reminding me of Bruce Hoover's article in the Spring 2003 issue of the AAW Journal. That design fit the bill exactly.
Last year at the Anderson Ranch, Art Liestman was nice enough to loan me his Jamieson captured hollowing rig (with Kelton Hollowing tools). I liked it so much, I ordered the tools that day. Later in the year, I built the tool support out of plywood, as shown in the instruction with the Jamieson capture rig, but was not sure abou how I was going to mount it, since even with the bed extension on my lathe, it was too short. Then when I extended my shop, the placement of my rolling turning tool chest/ Grinder bench, suggested to me that placing the tool support on that, would be just about perfect. But, I was not working on anything at that point, so I had no chance to try it.
Then during the last 8 weeks, I started working on a new series of hollow forms. Now, sometime I build my hollow forms in two pieces (and segmented stuff is already mostly hollow anyway) but mostly I do them whole, and then final hollowing after the outside shape has been determined.
Well, three times during the last month, while finishing the upper half of a HF, I caught my little swan neck in the mouth and broke the top. One really good thing about segmenting, is that this does not necessarily mean it is gone - I just rebuilt the tops. However, it got me thinking about the hollowing rig again, and especally the laser holder/adjuster I bought from Donald Derry. I thought about the laser when after successfully hollowing one HF, and then putting my thumb through the top. The hole was too small to measure through - it felt good, but obviously was not. Rebuild time.
So today, I finished all the details on the Laser Holder attachment, found the bushing I needed to use my little Sorby Swan Neck, etc, etc.
Well, I just got done finishing up the neck of this one. Smooth as Glass, and without that little knot in my stomach the whole time.
I always enjoyed the challenge of hollowing, liked my Pencil arm brace system, many times reverted to my old Sorby Hollow Master with a straight handle for final finishing. But all of it was always done with the knot in the stomach. This is great.
Thank you all for the help.
Mark
Dick Hines
Dick Hines
>I have been useing the Kelton captured hollowing rig for about 4 years and love it. I have 2 sets of hollowers that fit it and am going to order the 1/2' ones shortly.
I still do quite a bit of hollowing free hand. Mostly small pieces though.
I would suggest you get a steady rest. It will take a lot of the movement out of a large hollowing.
Re: Hollowing Laser Holder *LINK*
>Thanks, Dick.
It is hard to see in the photos, but I use two Oneway Bowl Steadies, one on each side. I have the front one out of the way for the photo (because I had been sanding, but then decided to take and post the picture). They work very well for me, but someday I want to get one of Keith Clarks big steady rests.
Mark
http://www.theokspindoctor.com/rest.html
Mark - couple questions
Stuart Johnson
>First would you post a couple larger pictures? I would like to see more detail.
Second, what wall thickness do are using on your segmented pieces?
Re: Mark - couple questions *LINK*
>Stuart,
Here are some pictures.
I generally hollow down to about 3/16" on the top and maybe a little thicker toward the bottom.
Mark
http://www.markkauder.com/Laser.htm
Thanks Mark.
Stuart Johnson
