Veritas - Innovation in Tools
Tagua nut piece
Tagua nut piece
Tagua nut piece
>Since I haven't turned Tagua nuts in a while and I'm doing a demo on friday I thought it might be nice to brush up on my techniques. Here is a Tagua nut vessel and base. The nut is about 1" and base about 2". Sanded to 600 grit and finished with laquer. I did use the beal on the base but not on the tagua nut.
Even though it is fun turning tagua nut vessels I prefer to use Tagua nut as an inlay rather than a stand alone piece.
Re: Tagua nut piece
Re: Tagua nut piece
John Bussom
>Really nice John,
How do you hold something that small on the lathe??????
I have alot to learn!
John
Re: Tagua nut piece
Re: Tagua nut piece
Russ Babbitt Jr.
>If you don't mind. After sanding I use Brasso as a final sanding polish and finish. I like the high gloss result. Nice piece.
Re: Tagua nut piece
Re: Tagua nut piece
Sam Scalzo
>John
Very nice. I have turned a few but I have had a hard time finding any that are very solid.
Sam
Re: Tagua nut piece
Re: Tagua nut piece
>In this case I turned a tenon on the tagua nut when I had it between centers. I mount the nuts between center with just enough pressure to hold it. Then I take a few light passes and look at what was removed and then readjust the centers if necessary to get the best profile I can. When I get it centered where I want I turn a small tenon. In this case 3/8" which was too big. I should have gone to 1/4" so the base could have been smaller.
I turn a tenon on the wood while it's between centers and then mount this in a chuck. I drill a 3/8" hole in the end and glue the Tagua nut to it. Then I can turn and hollow the nut.
Another good way to turn the nuts is to simply sand a flat on one end and glue this to a piece of wood that you put in the chuck or faceplate. Then you can turn the nut and seperate it from the wood.
Re: Tagua nut piece
Re: Tagua nut piece
>Russ On these with a lacquer finish I find 600 grit is fine. Using Brasso can leave white streaks inside the cracks that are in the outer crust of the tagua nut. In fact white diamond wheels will also leave a residue in natural edge portion.
I usually go to 600 grit and then 4/0 steel wool and then white rubbing compound followed by a wax. That produces a glass surface on the nut. You will still get finger prints on this so I switched to the lacquer finish.
Re: Tagua nut piece
Re: Tagua nut piece *LINK*
>Sam That's part of the reason I use them for Inlays. If the nut lookes like the void runs into the edges I simply core out some circular plugs or slice off pieces to be used in other turnings.
One trick I tried that worked well is to cut the end off the nut to find the void. Then I fill the void with system 3 mirror coat. This epoxy becomes very viscous as it starts to react and will run into the finest cracks. this fills the voids and cracks and lets you turn the whole thing. I was at woodcraft today and started to buy some more but the cost has at least doubled and I decided to pass it up. I don't sell my tagua nuts for enough money to pay for this.
http://www.woodcraft.com/family.aspx?familyid=4140
