finish recommendation
Dave L
>Box Elder-----what finish do you recommend in order to not darken the white and red of the wood? I think the oil mixture finish I usually use will darken the wood more than I want. thanks for the suggestions.
Dave
Re: finish recommendation
>I use Lacquer. If you want to maintain the contrast Bleach the wood. The white will get whiter but the red will stay the same. Then when you put a finish on you won't loose so much of the white.
Dick Hines
Dick Hines
>Just buff it out. I do this with holly. I use the Beall system. Just stay away from the red bar.
David Breth
>I've tried the minwax poly wipe on with some success. The "white" goes a little yellow, but not much really, and the red stays pretty red.
David B.
Dave L
>Thanks for the suggestions.
Dave
Carole Valentine
>I agree with Dick, just sand very finely then buff. But if you really want to apply a finish without yellowing or darkening the wood, try a water based poly. I have used it on a couple of pieces of BE and it worked well. I always bleach Box Elder with the 2 part wood bleach.
