Outboard Lighting...
Peter Teubel
>Awhile ago, I purchased a light stand from Gary Evans (http://www.turningwood.com/light_stand.htm). It mounts in the back of the lathe. But once I got the dust hood, the light couldn't swing around it to get to the outboard side. Since I have 2 lights mounted on top of the dust hood, I just mounted the light stand in FRONT of the lathe under the headstock. Now I have plenty of light anywhere on the outboard side.
- Pete
Re: Outboard Lighting...
Richard Allen
Richard Allen
>That is absolutely beautiful!! I have lusted after the Moffets and light stand for years. Once I got the dust hood the light stand has become less of a possibility. I very much like your solution of the Moffets attached to the top of the dust hood.
Remember...
Peter Teubel
>None of the lights are permanently mounted. Just the stud connector is. I can still un-clip the lights and move them wherever, using the magnetic mounts or other stud mounts.
In fact, I have another light that I sometimes use with the magnetic mount on top of the dust hood...shining thru the BACK window.
Evans vs Sanders :)
Dave Peebles Lyons, Ohio!
>Hi Pete,
Nice set up you have there. I have not pulled the trigger on the Moffits.... yet. :) But isn't that Gary Sanders who sells the lights? Instead of Gary Evans.
I may be wrong, but I thought I would ask.
Best wishes,
Dave
My bad...
Peter Teubel
>Yes, you're right. Senior moment....at 44.
