How to build a new workshop from scratch?
Pat Taylor
>I need more space for equipment (don't we all!) and I'm considering building or buying a shed or other enclosure in the backyard, running electrical, insulating, etc. I've got the green light from SWMBO (maybe she just wants me out of the house... ?) so I've got to make a move (pun intended).
If you have ANY experience in this area, please share! I have no idea where to start, so everything helps. Thanks!
Pat
Re: How to build a new workshop from scratch?
Carol from AZ
>Lucky you!
List your equipment, that which you have, that which you have a reasonable likelihood of acquiring. Go to Grizzly's website and download their shop designer program (free). Be mindful of storage, assembly, and finishing areas. Don't forget room to work around the equipment! Find what your local municipal's requirements/restrictions are. This addition becomes an investment for future resale of the property or an eyesore that needs to go away later. Plan a budget. These things always cost more than you think. Been there. Done that!
Keep the LOYL in the loop with decisions and choices.
The electrical, insulation, etc. are just the techical parts. First things first. Don from Arizona just finished his shop. He will probably pipe up here as well. Post your 'dream' on the main message board (left menu). You will get a lot of response there as well.
Last, but not least, peruse 'Shop Tours' way down on the left menu to see what other people have done. Lots of pictures.
And have fun, you lucky dog!
>Go to grizzly.com and click on the "Build your Dream Shop" icon. Make and populate a few trial floor plans. I tried the Easy Shop (freeware) when designing my new shop, but I wasn't impressed.
>Pat In my area it's cheaper to buy a ready built tool shed than it is to build it yourself. One of my friend bought 2 of them and put them together with a doorway inbetween. This gave him a large shop in a very short time.
eaglesc
>Buy the biggest one you can afford and mortage the materials for one that would double the size.
Mike from Tn.
>Whatever you decide,,,,Add 5feet to the width and 10 feet to the length. Mine's 24x40 and wish I had more. I also went with 10ft. ceilings too so I went up with a lot of storage. Although this takes a little more to heat I'm glad I did. Make sure you make your door wide enough for material in and projects out. I put in too many windows, thinking about natural lighting, and lost too much wall space and wound up framing some back in so I could hang cabinets. You can never have too many outlets or lights. Make sure you have a dedicated area for chemicals-paints lawnmower gas etc.. Have a fire extinguisher in plain view and check it every 3or4 months. My wife reminded me that I spend alot of time in my shop alone, you never plan on anything happening but as any wood worker knows, it does. I'm lucky enough to have My wife's blessing to work with wood, so I'm twice as safe in my homeshop as I've ever been on any job. So keep safty in mind when you design your shop. I have an intercom system to the house, not just for safty but to let me know when dinner's ready too. I found if I let my wife make a few of the desions, I got away with a little bit more. You know the old saying,,If I had it to do all over again. Take your time and add value to your home, not something your going to have to tear down if you decide to sell. Good luck.
Webster Stump
>Pat,
I just built a 24x18 pole barn. All said and done with, i think it was a good size for what I used it for and better yet, it was easy to build. You can call your local lumber yard and tell them what you are looking to do, and what size building you want. They will design it for you, give you a blueprint on how to erect it and give you a list and cost of the material to put the shell up. If you decide to do this, dont forget window and doors. I did this same thing and it went pretty smooth.
Bill Hale / The Wood Spinner
>There is no way to say what size you need without knowing what tools you want to be in there.Two things that I will stress is a 10' ceiling and an equip. room for your compressor and vacuum system . I also like a spray room for my finishing. I have three lathes, table saw, drill press, jointer, band saw, cutoff saw and a table for glue up or assy. work. There was also a spray booth and an equipment closet. Size 24 x 36 and it was ok but I also had another area to store rough bowls and wood.
Good turning and be safe
Bill in Casa Grande, AZ.
Bob Fawcett
>Depending on how large you go, you may want to consider a metal building. They are relatively cheap and go up fast. My friend who is a luthier put up his shop that way. A quick google found a 24 x 36 for $6500.
don lewonczyk
>Pat, I have a 30x40x12' side walls and im still cramped for space. It's a metal building, insulated and central h/a. It has 4 skylites and on a sunny day you can work without lites on. The bad things are in the summer the a/c can't keep up with the heat. The guy put in a 21/2 ton instead of a 3ton and said it would handle it but it doesn't. In the winter all the heat goes to the ceiling and a lot is lost thru the fiberglass skylites. Should have got the insulted ones. I recently put two 6" flex ducts dropped down to put heat down on the floor and it helped some. I think I'll still get a couple of infrared hanging heaters and put one by the lathe and one by my saw and wookbench. My trouble is I have to many things that I like to do and my better half said a thousand foot long building still wouldn't do for me, next I'd want a trolley put in so I wouldn't have to walk so far. I would skip any windows unless you like looking outside and I'd take Carol's advice and go to grizzly for your footprints on the tools and most sensible way for your work to flow, one station to the next without a hassle. I have plenty of electrical outlets some are just to one tool but I still have extention cords everywhere,more stuff to trip over! Four years ago the building put up, wired, a/c and 2 JDS air scubbers cost me almost $28K. The metal as you know has gone up about 30% since then but when you figure the difference between a pole barn and a metal building it wasn't that much different. Oh, mine also has a 20' overhang where the 10x10 garage door is so I can cut up my stuff outside even if its raining. Dollar wise I think the all metal building will hold its value longer and maintenace on one is very little, all in all Im happy with mine. With a cattle farm I don't get to use it during the winter to much after being out side feeding and everything else im just to tired but I do go down and fondle some of my tools some of the time. I'd do alot of research and know exactly what you want, what your willing to spend and then add a couple more thousand now instead of wishing later that you should of done it while the building was going up. Just my thoughts. If your in cold climate have a back up heater so your stuff don't freeze if you lose power a 3 or 4 stack LP wall heater would do and a hundred pound gas bottle which can be placed right against the exterior wall, bigger tanks have to be 10' or more from any building. Good luck with you building and hope you get to enjoy it. DonL
don lewonczyk
>Pat, I guess I didn't answer your question right. If you went with a metal building they would supply you with the blueprints. Then you have to find someone good in the concrete business who would lay out the places for your bolts for the truess, then according to spec's pour the floor. You would also be responsible for hiring a good crew that has done metal buildings to put yours up unless you plan on doing it yourself. Unless you have a lot of time on your hands I wouldn't advise it. Mine went up in 3 days with 4 guys doing the work which included them unloading the trailer that delivered the metal. The cost was $3,500.00 for that part. The cement and labor was $3800.00. The insulated 10x10' garage door was $600.00, well worth it BTW. The H/A and wiring was $5.200.00. The air scrubbers were $600.00 for the two. I think the building with overhang was $12,000.00 delivered. The insulation was $1200.00. I proablly forgot something, oh the pad, preparing the building site was $1,500.00, had to bring in dirt to build it up and grading it level. Make sure you give the pad plenty of time to settle or you will have cracks in your concrete. If you want to ask me anything else your welcome to email me. DonL
Lee Buck
>Pat, Several people mentioned windows. My 20x24 shop is on the side of a mountain behind my house. The walls are mostly windows and the view and the sense of being in the woods is important to me but, as pointed out by others, I have to find places for many things that could be put in wall cabinets. For me the windows are worth the problem. If I were looking out at the neighbors' garages I'd rather have the wall space. Also all the equipment I have is on view for any passersby; not a problem as I have no passersby, but you might.
Don in Northern Arizona
>Pat,
I don't know if you are in the cold part of the country or not, but I decided to make radiant floor heat one of my higher priorities. I use an electric hot water heater, not a boiler and it works great. Secondly I wanted lots of light and light reflective walls and ceiling. I went with painted drywall instead of OSB or plywood walls for the fire safety and lightness. I used a combination of T8 fluorescents for general lighting and track incandescent task lighting over work areas and my bench. The heat system and lighting was expensive, but well worth it to me. My shop is 18x30 and I do flat work and turning, so it is a bit crowded but will be adequate once I get my storage furniture built. My dustcollector will be out in the attached garage for noise and space considerations.
HTH,
Don
