Not all Norton SG are created equal
Gordon Seto
>The forty some dollars wheels are not the same as those selling for hundred dollars.
The expensive wheels from CSUSA are far better quality. They are the best. The only disadvantange is the hole is only 5/8"; you can't use the Oneway wheel balancer. The explanation that CSUSA gave was the SG wheels are so balanced that we don't need to use the balancer.
I recently purchased a pair of cheaper Norton 3X SG wheels (Med. Grit 60 and Fine Grit) from Hartville. They don't have any hardness alphabet rating (I, J, K etc.). May be they are not intended for grinding HSS tools; they hardly perform as well as the real SG. On my 60 grit wheel, it grooves real bad. With very light touch, not even the weight of the tool, I couldn't even rounding the heel of the bevel of one tool without dressing the wheel. It is not even as good as the OEM AO wheels that came with the cheap Woodcraft slow speed grinder.
I don't know whether I got a defective wheel or what. They are very disappointing. BTW, I can use the wheel balancer on them; they run very smooth. On the fine wheel, It doesn't wear as well as the expensive one.
IMO, either cough up the big $$$ or stay with AO. You got what you paid for.
Gordon
