Buckeye Burl Mini
Carole Valentine
>Another mini about 2". Natural edge is lightly burned. This is a piece I did quite a while ago. This was turned from a leftover scrap of the Buckeye Burl that Rev Doug sent me.
Buckeye Burl Mini
Carole Valentine
Re: Buckeye Burl Mini
Carol from AZ
>Incredible! Love it!
Re: Carole- photo class is now ....
Jamie Donaldson
>... in session! Reduce the amount of light on 1 side so they aren't balanced like this, and the appearance of depth(#D) will be eb-nhanced. That will also reduce the intensity of the 2nd highlight, and the pair of highlights won't look like headlights, even when crooked! Looks like your're getting some good practice with the new camera, and the color as well as exposure are excellent
Re: OOoppss- spell check/edit error!
Jamie Donaldson
Pic may not be PERFECT, but the turning is !
Brad Vietje
Wayne Leach-NW Ontario
>Incredibly gorgeous with such depth. Wonderful work.
Wayne
Carole Valentine
>Thanks, Jamie. I am having a struggle with lights as you can tell!
RevDoug
>It is beautiful, Carole. I sure am glad I sent it on to you. So nice.
Turn 'em round,
Dave Peebles Lyons, Ohio!
>Hi Carole,
This a great piece. I really love it.
But I can't really believe there was a photo critique on it. It really looks great to these old eyes. :) The detail really jumps out on my monitor. It looks fantastic!!
Great turning and pic,
Best wishes,
Dave
George Van
>Perfect form Carol, "Spot On". I really like the color and saturation of your photo, my white balance does not seem to adjust as well. Did you correct this with editing software?
Thanks folks
Carole Valentine
>George,
I manually set the white balance using a white card in the booth. Not perfect but better than the orange or blue tint my old camera gave me with it's preset WB settings. I still have to fiddle with the levels a bit because the pics are darker than I would like, but I don't have to mess with color balance any more. I think once I get a better understanding of how aperture and shutter speed affect the exposure I may have better results. I am using a small aperture (the higher the number the smaller the aperture - is that right? That always confuses me!) to try and get more depth of field. I have then been adjusting the shutter speed so the exposure meter reads 0, but I think I need to slow the speed a bit to lighten the picture. This manual control is all so new to me - a photographer I am NOT! LOL I also need to get some better lights than the jack-leg setup of household and painters lights I am using. :)
Gil Jones, Lake Seminole, GA
>Carole,
Your photo looks fine to me.
The little hollow form is gorgeous,
and I really like that wood!!
Gil
Re: Carole-for most of my shooting ....
Jamie Donaldson
>...with a white background, I find that an exposure compensation of +1 works very consistantly. Save that as part of your custom setting with WB and you will be able to fire away with little need for major software corrections. Have you checked the lighting set-up I use in the Phrugal Photo tutorial located on the tips menu on my website at jamiedonaldsonwoodturner.com Using a single light source solves many problems, and the higher numbers are the smaller diameter f stops that = more depth of field.
Ron in Drums PA
>Really Nice Carole
Is this from your new Camera?
Re: Thanks folks
George Van
>Carol, looking at the photo you are a photographer, each time you use the camera you will become a better photographer. I have tried a gray and a white cardboard card and still have to adjust after the photo, maybe my camera is not very accurate. I like Jamie�s idea of creating a custom setting once you have what you want so you don't have to keep �setting up�. I also like higher numbered f stops to eliminate the distortion as much as possible.
Re: George- I'm curious about your ....
Jamie Donaldson
>.. comment regarding f stops and distortion? The f stop has no relevance to any distortion, but focal length numbers of the zoom lens can dramatically distort at the wide angle settings which are the lower numbers.
George Van
>Thank you Jamie, I thought if used the higher f stop I would lower the distortion by stepping down the opening of available light as I zoomed in. It must have worked due to the higher focal lengths I was using with no bearing on the f stop setting. After your pointer I may be able to shoot (mounted on a tripod) at a higher shutter speed and possibly eliminate the self timer for release? Your advise is always appreciated.
Ron in Drums PA
>Longer focal lengths (as in telescopic lens) have less distortion then short focal lengths (as in wide angle lens)
A lower f/stop (smaller number) will bring less depth of field, which means the background will be out of focus. A higher f/stop (larger number) will bring the background into focus.
Carole Valentine
>George, I always use the remote (or timer, if no remote) when using a tripod no matter what my shutter speed. Usually with a small aperture for good depth of field, I have to settle for a somewhat lower SS. I just feel like the camera is sensitive to motion that I cannot detect when pressing the shutter manually even with the shake reduction. I guess it's possible that that may not be the case at very high shutter speeds.
George Van
>Thanks Ron and Carol, after this I will better understand how to set-up properly. I will continue to use the self timer button and the tripod.
