A55 Smoothing Plane
Random orbital sander (long)
David Walser
>There are two air powered random orbital sanders that I am aware of that might be useful for use on turnings: the Grex AOS368 - 2" 105� Angle Random Orbital Sander and the Chicago Pneumatic 7200S Mini Random Orbital Sander. I'm currently using an electric drill for power sanding. A random orbital sander would make sanding scratches less noticeable. Besides, it would be a new tool! The question is whether my 1.5 hp - 8 gallon air compressor can power either one of these effectively?
Having found the manufacture's website for both sanders, it appears the Grex uses 2.2 cfm at 90 psi -- something a small shop air compressor should be able to supply. (It would be noisy, unless you could put the compressor in a cabinet to deaden the sound.) The Chicago Pneumatic uses a lot more air: 21 cfm "under load" and an average of 10.5 cfm (no mention of psi -- if you have to ask...?). It would seem the Chicago Pneumatic requires more air than a typical small shop compressor would deliver.
Here's links to the two websites:
(Chicago Pneumatic)
(Grex)
Here's links to the sanders on Amazon (so you'll have an idea of the cost, they're available elsewhere):
(Chicago Pneumatic)
(Grex)
Anyone have personal experience or thoughts they'd care to share?
Re: Random orbital sander (long)
Donna Banfield
>Hi Dave
I have the Grex ROS, and tried to run it using a Porter Cable 6.5 gallon, 11 cfm (pancake) compressor. Despite what the specs might say, you will bog down after a few seconds.
Shortly after I upgraded to a 60 gallon Husquvarna compressor. I now use it to run the Grex without any problems and it never stalls. Regardless of the compressor used (as far as size) they will all be noisy unless you have them in another room. I use ear protectors to deaden any noise.
I still use a power drill for sanding, with grits from 80 or 100 up to 220. I then switch to the Grex, beginning with 240, and the technique I use would be a 'finesse' of the surface. This question has been posed before, and if you do an archives search you might find the thread. Another turner (maybe it was Keith Tompkins) called it 'kissing' the surface (but I could be mistaken as to the turner -- my apologies if my memory failed me tonight).
You can't use the same technique with a ROS that you would with a power drill to sand; you can easily 'stall' an ROS with too much pressure, and this will put a swirl pattern in your work. With practice, though, you can achieve an incredibly smooth finish.
Lan Brady
>David,
I have the grex. For me it works great. I run it at 40psi. It has never bogged down and the sears compressor , 30 gal tank will run it for about 15 minutes before the compressor kicks back in.
Everyones experience will be different, but I use it on all projects.
Lan
The Grex will run on a small compressor if
Doug Thompson near Cleveland
>you adjust the screw on top of the handle, run it in a few turns. The ROS doesn't need to run wide open.
Juergen
>I have the Grex as well and use it with a 30 Gal compressor. Running @ 90 PSI the compressor will kick in after about 5 minutes. I think the real CFM on this unit is really around 6 CFM. Usually it will rum for some time before it begins too stall. Any pneumatic sander can be used as inertia sander, so when the air runs out I just let off the trigger and use it as an inertia sander till the compressor recovers.
I've read comments by "sandpaper experts" the RO sander is most effective when used with the coarser grits. At the higher grits RO becomes less effective because the grit pattern is not visible and non-RO sanding will work just as well. I've experimented with this and confirmed the proposition.
don lewonczyk
>David, Packardwoodworks.com has or had the grex ros on sale for $99.95 normally $115.95. I have been wanting one also and believe it is a good choice for the final finshing. They also have the grex air drill when one sale for $89.95 normally $99.95 and I think that would be a great combo. I have sereral other sanders but am not completely satisfied with the end result so I think I will have to take my own advise and talk the sweet talk to the BOSS. Take care, DonL
