Bowls vs Hollow Forms.....
Wally Dickerman in Arizona
>At what point in closing in the upper portion of a bowl does it become a hollow form? I teach a lot of classes in bowl turning and a few in beginning hollow forms. Most of my hollow form students have been in one or more of my bowl turning classes. Often, a student has been turning bowls that are closed in a bit and the question on when it becomes a hollow vessel arises..
What do you think? Or is it a silly question?
Wally
Re: Bowls vs Hollow Forms.....
Ron in Drums PA
>IMHO a hollow form is when the biggest thing you can use to sand the inside is your finger.
>Wally I've been asked that also. I think it has to be a small enough opening that you can't use it as a bowl. Just to thrown wood on the fire where does a vase fit in with this. Probably between the bowl and a hollow vessel. Kind of like discussing smidgen vs a pinch which is bigger.
>Funny, I was just talking to David Ellsworth about this the other day. He gets this question all the time, and his take is that if the opening is smaller than the major diameter, it is a hollow form. By that reasoning, a bowl with a turned-in rim would be a hollow form, but it would still be a bowl. David didn't mention where the crossover point is, and I suspect there isn't one.
Thats easy...
Bob Fawcett
>Will a spoon fit through the opening? :-)
Re: Soup spoon, stirring spoon, salt spoon,.....??
Jamie Donaldson
Re: Thats easy...
georgetroy
>If you can't reach the inside part with a gouge, then you are undercutting and that would certainly be a consideration for a hollow form. GT
Ed in Sptbg.
>If you can get your hand in it and it's still useful, it's a bowl.
>But if you make a fist to get the food out you can't get your hand back out. Therefore it's a hollow vessel.
Jim King
>To me a hollow form is when you cannot finish the soup without tilting the vessel.
Rick Pixley
>Wally,congratulations on your award...My personal definition.perhaps over simplified.is a gowl gecomes a hollow form when you cannot turn the inside with a gouge...Take care,rick
now u know, wally
bob davis
tm
>When I cant decide I just call it a semi-hollow vessel.
Bob Fawcett
>Soup spoon = soup bowl,
salt spoon = salt bowl,
stirring spoon = sugar bowl
Dick Hines
Dick Hines
>When you can only get one finger in at a time and you don't have to sand the inside.
Steven Smith
>If it isnt good for anything except to look at, its a hollow form.
Steve Kubien
Oh c'mon!
Steve Kubien
>A smidgen is 0.2746 of a pinch. What, am I the only one using the newer metric system?
Steve Kubien
>Okay, what would you call the much copied, beautiful pots made by the ancient SW Indians? Most were partially closed in at the top and all were funtional.
Wally
Re: When it is no longer useable
Russ Fairfield
It that a trick question?
Brian Hahn in SW Wisconsin
>Pots are pots. The orignal pots are pottery pots. The turned pots are wooden pots.
Now, what is the difference between a pot and a vase?
Re: Seed Pots; Water Pots; etc..
Allen Neighbors
Re: Wally, it's not a silly question... but
Allen Neighbors
>if you don't know for sure, no body does.
That's a fact, Jack... er, uh, Wally, and you can take it to the bank.
Re: That's too easy Wally- we call them pots!!!!
Jamie Donaldson
What Do You Call Them if They're Tuned Wood Copies
Turned SW Pots?
Ron in Drums PA
>Beautiful?
