First Solid Segmented Bowl/Vase *LINK*
Dick Parr
>I finally decided to try a solid segment form and I can't say as this first one was fun. I had a few problems with the dim. of ring sizes from a book I used and had to make some over. But I am happy with my first attempt.
It is made from Walnut, Cherry, Yellowheart and Ebony. There are 166 pieces total and it is 7-1/2" x 8" and is finished with antique oil and buffed with wax.
Thanks for looking
http://[IMG]http://i62.photobucket.com/albums/h84/DickParr/FinishSeg.jpg[/IMG]
Re: First Solid Segmented Bowl/Vase *LINK*
Dick Parr
Stay with it ...
Bill Youngblood
>Dick. It will get easier. This looks pretty good for your first one. Always keep it and in a few years you will look back and see your advancement. My first bowl still sits in our livingroom. We keep it full of nuts. There are a few computer programs available for designing and ring sizing. The one I use has a free trial program at www.woodturnerpro.com Good luck. Bill
Re: Stay with it ... *LINK*
Mark Kauder, Phenix City, AL
>Thanks for posting.
You did not say if you would like some suggestions/critique.
Mark
http://www.markkauder.com
Dick Parr
>Sorry for forgeting to mention it Mark, thoughs are always welcome.
Thanks in advance.
>Dick,
It looks like you have a great handle on the mechanics of making a segmented bowl. Joint tightness is good, and joint alignment is good. The mechanics are tough at first, with practice they get easier, but always require out attention. Consider the Woodturner Pro software, It is cheap, and allows you to forget about the calculations, and concentrate on the bowl design.
Next: A couple things to consider when/if you do the next one:
1) Never let the ring construction dictate the shape of the bowl. It is quite the opposite. We segmented turners have the luxury of deciding what we want to turn, and then building the wood to suit that design. IF you mess up a ring, you can turn it off and start again with another.
2) Don't try to scrimp on the wood. Some people think that segmenting is a good way to use as little wood as possible. Make the walls of your rings thick enough to allow for error, and for design changes. I almost never make the walls on my rough segment rings thinner that 1.25".
3) Never let your chucking method dictate the shape of the foot (true in any woodturning). Use enough of a waste block to let you turn the bottom that the piece needs.
4) When you look at the shape - ask yourself: "If this were a solid wood bowl, would the shape still be pleasing". I tell people that (at least in the past) segmented turners on the whole turn some of the worst shapes in the world, mostly because they spent all their time worrying about the rings designs. Additionally, they saw other segmented work and decided that it was the way segmented work was suppose to look - a good deal of it has horrid shape. Non-segmented turners are often intimidated by the work involved in segmenting, and as such are loath to tell a segmented turner that the shape of his work is not up to par (then again so are many solid wood bowls), so they tell the segmented turner how great the wood is, and how hard it much be to make, etc, and never tell them that the shape could use some refinement. The ends up being positive re-enforcement for ugly shapes. We have all done it - it is part of the learning process - grow beyond it. Shape, Shape, Shape. In 20 years all the wood will be dark brown or gray, but the shape will shine through.
Your piece is not ugly. It could use some refinement. I applaud you for trying segmenting. Most don't.
Good luck in your future work.
Mark
Dick Parr
>Thank you Mark
Re: Stay with it ... Dick Parr
>Dick, (and everybody)
My use of the work Ugly was a really poor choice of words and used in a poorly phrased sentence. What a was meaning, was that if you have a scale that goes from Stunning to Ugly, yours is not on that ugly end. After re-reading it this morning, I realized that some might think I was "damning with faint praise". I was not. You have made a good start, and you should keep it up - refining along the way.
I should post some of my first attempts, but I did not have a digital camera then, and I think that I have successfully acquired and destroyed all, except the ones my Mom has.
Keep it up.
Mark
