ADVERTISE HERE - FREE TRIAL
General 260-20 owners
Bart Rhoads
>Has any of the General 260-20 owners had a problem with trying to keep the tailstock from moving? I have had this problem from the time I bought it while trying to rough turn large, rough, out of balance pieces. According to David Elsworth you can make a bigger locking plate and that will solve the problem. So I made a new larger plate but I cant see any difference. I still have to use a hammer on the lever. My next try is to make a larger handle, but I dont think that is going to solve the problem. Is there something I can do to the locking plate or the tail stock to give it more grip? Any help or ideas?
Thanks
Re: General 260-20 owners
adrien
>I did turn a good-sized handle out of maple. It gave me much better leverage for locking the tailstock into position. Only problem was when I brought tailstock to end of ways, had to get handle up so's it wouldn't be blocked by the back end of the lathe. I like it a lot better than the puny standard one. (Just turned a handle, drilled a hole and then threaded it on.)
adrien
Ruth Niles
>I had that same problem and, believe it or not, I made a handle like Adrien's only a bit longer. It really did help and with that extra leverage, you don't have to pound down on the handle. Try it, all you've got to loose is a block of wood.
Ok Thanks I'll try the new handle
Bart Rhoads
Re: Ok Thanks I'll try the new handle
Bill Crommett
>Bart: The handle is a good idea, but I found that a little water in the form of wet paper towel applied to the underside where the locking plate contacts the bottom of the ways and left over night caused a little rust which gives a better grip. David Elsworth a long time ago recommended allowing the ways to get a little "patina" to help hold the tailstock in place.
Bill
Bill Crommett
>By the way, has anyone out there had to replace the Altivar speed control on the General 260. I have been trying to get mine repaired for two months and am looking for a good replacement inverter. The Fluxmaster looks good, but after reading the 64 pages of the operational manual I am not sure I could do a good job of installation. Any help out there ??
Juergen
>I also extended the handle. However, I found the extended handle would fall to the right and catch on the rear leg. I solved the problem by tapping a hole and turning a support on which the handle can rest while released.
Bart Rhoads
>Yea I had this problem also. I disassembled it and install a split pin at the correct place in the shaft at the open area on the inside of the tail stock. Just another idea. Worked for me.
georgetroy
>My 1987 General 260 had this same problem with or without the riser block. I just tapped it down harder. I later sold the machine and put a Robust in it's place. A little expensive, but end of problem. GT
Re: George- that was a back door gloat!!!
Jamie Donaldson
Keith Tompkins
keith tompkins
>Bart, a suggestion....over time, the locking mechanism gets dry, and lots of friction results. When this happens, much of the energy you are expending is used to overcome this friction rather than securing the tailstock. What I do periodically is to take apart the tailstock, and lube the moving parts. If I notice any signs of galling, I polish the surfaces and apply grease before reassembly. While I'm at it, I clean the sliding surfaces on the tailstock, then lightly chamfer the edges. I do the same maintenance to my tool rest as well. (I can easily slide my toolrest with one hand over the bed using just the clamping handle.) When turning large pieces, I regularly snug up the tailstock lever as well as the spindle. While I own a General as well,I do this on any lathe as a matter of habit.
