Cryogenic hardening *LINK*
>I just posted this on the message side by mistake. I find Cryogenic hardening interesting but haven't bought any of the tools. I have friends who are knife makers and think it makes the tools tougher. Not harder but tougher. I also have a friend who is an ex NASCAR mechanic and said they cryogenically harden the axles and find that they hold up better. I thought you might find this article interesting. It's from an engineering firm
http://www.metal-wear.com/More%20Detail.htm#What%20Does%20Cryogenic%20Processing%20Do?
Re: Cryogenic hardening *LINK*
Richard Allen
Richard Allen
>Glaser tools have been cryogenic treated since 1995.
Steve Russell
>Hello John,
I recently completed a 3.5 year test of cryogenically treated woodturning and woodcarving tools in my studio and I thought you might be interested in my results. This was originally printed in my monthly woodturning newsletter "Lathe Talk"...
There has been a lot of buzz recently about cryogenically treated woodturning tools. I have had numerous emails asking me about them and if I'm using any of these new tools. I have been using Cryogenically treated tools for the last few years, long before any of the major tools suppliers began offering them to woodturners. There are many advantages to deep cryogenic treatment of tool steels, including these many benefits:
� Increased wear resistance - you can go longer between sharpenings
� One time, permanent treatment
� Creates a denser molecular structure throughout, not just the surface - you can't grind it away like some coated tools
� Transforms almost all soft retained austenite to hard martensite.
� Increases durability
� Decreases brittleness and residual stresses in tool steels
� Increases tensile strength and stability
Note: Tools that are cryogenically treated are exposed to nitrogen gas at temperatures of 300 degrees below zero for a specific period of time. This changes the structure of the metal, increasing its wear resistance.
As many of you know, I continually test tools and products that may benefit woodturners. As a part of this testing, I began a series of long term tests of cryogenically treated woodturning and carving tools. This testing ended last year and spanned more than three years. A professional Cryogenic treatment company called 300 Below, Inc treated all of the tools in my test.
The tools were shipped to the facility, treated and returned to me. Most of the tools were unhandled, but some retained their wooden handles. Leaving the wooden handles on does not present any problems for treatment. However, the handles will darken slightly as a result of the treatment, but will not loose any strength per the manufacturer.
Tools included in the testing were standard M2 HSS before treatment and included bowl gouges, spindle gouges, scrapers, parting tools, skews and micro turning tools. In addition, Kenton Center Saver knives, (Standard and Jumbo) were included for treatment with some Arbortech Industrial carbide carvers and standard Arbortech steel carving blades. A few homemade tools were also included made from shock absorber rods from automobiles.
As many of you know, I'm a professional production woodturner and I turn large quantities of wood regularly. To say my tools see brutal usage would be an understatement. After having turned thousands of bowls over the last few years, and several thousand different other items, I'm keenly aware of edge life in woodturning tools. I'm also a habitual sharpener of my tools, stopping to resharpen at the slightest hint of the edge starting to fail.
Through the years, I have always observed the wear rate on my tools, so incorporating this testing perfectly dovetailed with my existing protocols. I should mention that I have almost every alloy you can get in a woodturning tool, including M2 HSS, M4 HSS, ASP 2030, ASP 2060, A-10, A-11 and V-15, not to mention various homemade tools in different tool steels. I'm a big fan of some of the newer tool steels and use them regularly in my studio.
I approached the testing using this standardized protocol: Two identical tools from the same manufacturer were used for each test. One was cryogenically treated and one was unchanged from how the manufacturer supplied it when purchased. The tools were sharpened with the same profile and bevel and were sharpened on clean, freshly surfaced stones each time they were resharpened.
Primary testing was performed on 60-grit and 100-grit wheels on a dry grinder and 240-grit and 1000-grit on a Tormek wet grinder. An additional subtest was performed on the Tormek with the 1000-grit edge honed to a mirror finish on the leather buffing wheel to approximately 6000-grit.
My testing was necessarily subjective, but I think most woodturners would agree that it's quite easy to tell when you've lost the edge on your tool. Each tool was used for a specific period of time, and the resulting surfaces were examined under magnification. Care was taken to insure that each test closely matched the other, including using blanks from opposite sides of the same log for each tool.
The testing covered 500 bowls and several carving blanks for the carving tools. The carving tools were tested with blanks that were bark free and a few that still had the bark on. Results of the testing are as follows:
Cryogenically Treated M2 HSS turning tools in every tested category outperformed the standard HSS tools, averaging approximately 250% greater (longer) edge life. That means you can turn with your freshly sharpened edge much longer before it needs to be resharpened. In my testing, up to 2.5X longer, depending on the base tool steel.
Test results with the Cryogenically treated Kelton Center Saver knives produced an average edge life increase of 200%, vs. untreated knives. The Arbortech carbide carvers produced a stunning 300% better edge life when treated, while the steel carvers averaged 200% better edge life.
Does this mean that you should run out and buy yourself some cryogenically treated woodturning tools? It depends. If you were looking to replace a worn out bowl gouge, or other tool I would consider getting a cryogenically treated tool. Cryogenically treated woodturning tools are more expensive than the non-treated versions of the same steel.
However, you are rewarded with longer edge life, which makes your tool last longer in the long run. Cryogenically treated tools are not necessary to turn wood, but they're a nice thing to have around in the studio, especially when turning through bark, or when working with abrasive materials.
The main factor for me is the longer intervals I can go before needing to resharpen my tool. In a production studio, time is money. If you're turning for pleasure, saving a wee bit of time at the grinder may not be a benefit to you. There are several manufacturers offering Cryogenically treated woodturning tools, so give them a look the next time you need to buy a tool, or when you are replacing a worn out tool.
I still recommend the standard M2 HSS woodturning alloy for most of your woodturning tools. It is the least expensive tool steel in the HSS range and it works very well in most situations. Look at these Cryogenically treated steels and the other high-end alloys like the powder metals as "task specific" tools that offer the advantages of greater edge life in exchange for a higher initial cost.
If you would like to treat your existing tools as I did for this test, you may contact 300 Below directly. The treatment is charged on a per pound basis, plus shipping and there is a minimum charge. Best wishes to you in all of your woodturning endeavours!
Steve Russell
Eurowood Werks Woodturning Studio
The Woodlands, Texas
300 Below Inc.
Bob Fawcett
>Great article Steve. Thanks for posting it.
Are you willing to compare the "luxury steels" with standard M2?
Of the few bowl gouges I have, the Glaser A-11 seems to hold its edge longest. (Mine is one of Jerry's original versions.) This is purely subjective, and may be due to the fact I paid more for it and am "expecting the result". I have not done record keeping like yours, nor do I turn anywhere near as much.
Glaser/cryogenics Not anymore!
Doug Thompson near Cleveland
>Look at the advertising now. TRIPLE TEMPER with no mention of cryogenics. If they paid for it they would say cryogenics.
Cryogenics does work but it costs a good buck. More than some are willing to pay.
John Lucas send me a email. I make tools that use a cryogenic treatment.
Re: You want some liquid nitrogen anyway? :)
>Thanks steven. Most interesting. So if you made a gouge out of V15 powdered metal, cryogenically hardened and titanium coated you would never have to sharpen it.
