Tips for turning dry bowl blanks
Mark Trulock
>Hi
I'm a new turner, I took a weekend long class at woodcraft and really enjoyed turning a green bowl. When I tried to turn a dry blank I had a lot of trouble trying to ride the bevel and get a decent cut. Any suggestions?
Thanks
Mark Trulock
Re: Tips for turning dry bowl blanks
Brad Vietje
Brad Vietje
>Sharpen tool. Less bevel, and a little more edge.
Green wood is softer and more forgiving than dry, and some species more or less forgiving than others.
You can start with the bevel rubbing fully, tool on its side with the bevel in line with the direction you want to cut, and gradually change the angle between the wood and tool by slowly moving handle away from the lathe. When a tiny curl starts and you begin to pick up a cut, you can ease the tool forward. Once you get the hang of this, which is a pretty safe position to start, you can open the flute up a little, and start with the flute facing about 2 o'clock instead of fully on its side (cutting to the right -- 10 o'clock if cutting to the left). Just be sure not to try cutting on the wrong (unsupported) side of the bevel -- goes BANG !
Tool still sharp ? Now hone it very lightly to make it even sharper, and try it again...
Safe spinning,
Brad Vietje
Newbury, VT
Mark Trulock
>Brad
Thanks for the info. I will try it again.
Mark Trulock
Brad Vietje
One other important thing (Newbie Advice)
Brad Vietje
>This just occurred to me, but I see this all the time:
Say you mount a 6" by 6" by 2" square on a faceplate to make a small bowl or dish... Where do you put the toolrest ?
Well, NOT parallel to the bed, and out where the corners are whizzing by. If you start by knocking down the corners, especially on really hard wood like Rock Maple, Mesquite, or Cocobolo, you're in for a real beating. You also risk some unintended splitting as chunks of wood fly off to hit your faceshield, the walls, and nearby glass objects. Rather, if you place the toolrest across the lathe, and across what will be the bottom of the bowl, you can first true up the flat face, and then begin to bring the outer curve up and away from the eventual foot. In other words, you remove the corners of the wood by cutting arcs or curves from foot toward the rim -- toward the headstock.
Thinking about grain orientation and the direction that will give you the cleanest cuts (and the least sanding :-), you want to cut from foot to rim on the outside of a cross-grain bowl anyway, (and go the opposite way on the inside).
Sharp tools and good technique are still very important, but trying to beat those corners into submission is a recipe for a sore body in need of Ibuprofin, which my son calls "I-be-broken".
For absolute first-time bowl makers, I suggest going back to spindles for a while until the tools seem easy to use without catces, and then cutting round circular disks on a bandsaw until you have bowls figured out. After that, it can be pretty darned quick to just turn 'em away as I described.
Safe spinning,
Brad Vietje
Newbury, VT
Re: And keep the tool handle .......
Jamie Donaldson
>... angled DOWN, below the level of the tool rest. The rest should be at about centerline with the wood, and the gouge cutting slightly above center.
Jim Swank
>You do want to be cutting the outer edge above centerline, but you also want to be able to cut the very center at centerline by raising the tool hanlde slightly. You'll have to adjust the toolrest according to your gouge size and grind. You may end up with the rest below centerline - where you're cutting is the important part.
