Burning a Natural Edge?
George Van
>I have a natural edge bowl that the bark fell off due to spalting. I want to burn the edge rather than leave it "old brown cambium color" The problem I have is I do not have a detail type burning tool and as the bowl is turned to a finished edge I do not want to try a torch. Has anyone tried a simple soldering tool with good results? I have two soldering tools.
Re: Burning a Natural Edge?
>It's hard to use a soldering tool. It does work but it's awfully hot. You might try a magic marker. I have a friend who did that all the time. I use a propane torch.
Got torch?
Peter Teubel
>You can use just a regular propane torch. Turn the flame down as low as possible. Position the flame so that it's parallel to the edge as you go around and at a very shallow angle. Touch and go. The flame should scorch the edge but just flow over the side with little burning to the inside/outside. I tend to leave it, but you can always sand the scorching away for a cleaner edge.
Here's an early example:
Got torch?
Peter Teubel
Sorry for the duplicate messgage...
Peter Teubel
Brad Vietje
Re: Burning a Natural Edge? *LINK*
Brad Vietje
>George,
I used a pretty inexpensive pyrography pen, the Colwood Cub, which I got from either Packard or Craft Supplies USA. It costs about $60, and works well for signing work, too. The small tip, relative to a soldering tool, allows me to get into narrow crevases. There are also inexpensive woodburners with a narrow wedge tip, used for crafts, and maybe they would work, too.
Safe spinning,
Brad Vietje
Newbury, VT
Colwood Cub Woodburning Pen
Troy German
>Also, Harbor Freight sells a "micro-torch" that uses butane for $10. It might be worth a try.
Troy
Troy German
>Another idea - What about rubbing some candle wax or some other substance on the inside and outside of the rim before burning the top. That might keep the temp down on the parts you don't want to burn. Has anyone tried this? Did it work?
Just a thought,
Troy
George Van
>Thanks for all the responses.
Peter, the edge is under an eighth of an inch and I am afraid the heat from a torch might be too much for this one as it is quite spalted in places, it may crack or catch fire.
Brad, I am going to get one of those so I have it available for future projects, it will be handy.
Troy, I got an email on the same subject, I am going to get one at Menards when I am at the store next.
John, I am going to try the magic marker, seems safe and I am already sanded to 600 grit it should save me a lot of additional sanding.
Bob Fawcett
>Candle wax would catch fire.
Dick Hines
Dick Hines
>I have a small torch that run off Ronson lighter fluid. The torch has a very hot fine point. Now if I could just remember where I got it.
Why Burn?
Juergen
>The odds are that almost any technique you use may have some collateral damage. In situation like this I've used a couple of products depending on the wood and smootness of the edge. A thick indelible Sharpie will work nicely in most cases. Kiwi makes a shoe/boot sole edge dressing and they even provide the applicator. The Kiwi product is essentially a black quick drying lacquer.
Re: Why Burn?
George Van
>I never made it to the shop, worked too late on the paneling project in the house, hopefully today.
Juergen, I will check out the Kiwi products display, I will try it while returning a roughed bowl, if it dries like lacquer it should work good without the problems of heat.
