Turning legs - how do you do this detail?
Joe in a Cleveland suburb
>Hi,
Below is a pic (I hope) I cut & pasted out of a FWW magazine PDF. I am trying to show the part of the leg (typical on Shaker legs) of the area that transitions from square to round. It's like just the corners are knocked off. How is that done and which tool(s) is used?
Thank you,
Joe
Re: Turning legs - how do you do this detail?
How I Do It
Jim Shaver Oakville, Ont.
>Hi Joe,
I have made legs like this before. I turn the leg details like this detailed in your illustration. I use calipers and a parting tool to turn down to the proper diametr and then turn away the waste.
Photobucket - Video and Image Hosting
The same is done for the section at the square to round transition, I part down and then blend the detail with a small spindle gouge.
If you look for my Shaker Table in Shop Shots this is the detail from one of the legs on that table.
Hope that helps.
Take care,
Jim
Dennis Yoder
>The pommel cut is usually cut with a skew from square to the round. Check out Alan Lacers video The Skew, the sweet side and the dark side. Dennis Y
>Joe Sneak up on it. You can use a spindle gouge or skew. Start about an inch or less away from the square portion and then carefully cut from the square part down. Raise the speed of the lathe will make it easier. If you cut lightly you will get a feel for how it's cutting and how your body moves to get the shape right.
You will need the flute pointing toward the downhill side and you'll have to rotate the tool so the bottom wing doesn't cut the bead area.
Some people use the toe of the skew and cut a V cut to establish where the bead will be.
Steven Antonucci
Skew- practice first on a 2x4 that you've squared.
steve antonucci
Greg Haugen
>Joe,
The Lacer video previously suggested is an excellent point to start. The same option was just in print though also. American Woodworker (worker not turner) had an article on pommel cuts by Alan one month back if you know anyone with a subscription. The current issue has an article by him also on grinding his grind. Also below is a link to a different article that Alan wrote on turning table legs in general, pommels are talked about.
http://www.alanlacer.com/articles/table_legs.html
A spindle gouge will also work. If its still being stubborn I've found also my bowl gouge made an outstanding pommel. My gouges are ground though to a 40-45 degrees, they're not the standard 50-60. A skew will give the best finish, if you can get it to work. If not, there's no rule you can't use a gouge.
Good Luck.
Greg
Re: Turning legs - how do you do this detail? *LINK*
Ken Grunke from SW WI
>Joe,
I have a short video clip on the Woodturner's Resource site showing how I make that entry cut with a skew, into square stock which you might find useful. It's a Quicktime movie, 2.3 mb, "V-cut into square stock".
WR Woodturning Videos
Great idea! Will do.
Thanks all.
