Should I buy the Jet band saw? *LINK*
Pat Taylor
>I've been eying the 14" Jet bandsaw at woodcraft (beats amazon price) and I'm wondering if anyone has has any experience turning blanks with this bandsaw. Is the 6" capacity enough?
I realized that I spend a lot of my time rounding square blanks on the lathe, and I think it's time to give my tools and hands a break. Also, starting with round blanks increases the effective swing capacity of my lathe by not having the corners to turn away.
Is this the bandsaw for me, or should I keep looking? This is the price range I'm looking in. Thanks!
http://www.woodcraft.com/family.aspx?FamilyID=60002
Re: Should I buy the Jet band saw? *LINK*
>That's a good bandsaw but if you turn anything large at all you will be frustrated with the 6" height. If you can swing it buy the riser block with it. It gives close to 12" height and you will really find that useful.
Dick Hines
Dick Hines
>I have the 14" and after I installed the riser and went to 4TPI skip tooth blades I an very happy with it.
I do wish the table was a little bigger though. But for the price it's hard to beat.
Raymond Overman in SC
>You can always build an accessory table for your bandsaw.
Woodcraft's Version
There are other's out there too. Just use your Google-fu to find them.
Bill Youngblood
>I've had my Jet with rhe riser block for many years and am very happy with it. I recently added 'Carter roller guides' and now it's even better. Hope this helps.
Rick Allen
>The 6" riser kit is a good addition to a 14" bandsaw. But the 3/4 hp motor makes the saw under powered for that riser kit.
There are other tools you can use to knock off corners on your turning blanks. A chainsaw comes to mind. An electric chainsaw if you are doing this inside. A gas powered chainsaw has more woodturning potential.
I use my bandsaw on almost every turning project. 1 1/2+ hp on a woodturers bandsaw is a good starting point.
Not 100% true...
Joe in a Cleveland suburb
I don't mean to cause trouble but I just wanted to say this 14" bandsaw can work very well with the riser kit. I have the closed stand version with the Jet riser kit and a Wood Slicer 1/2" blade. I cut veneers with it out of walnut, cherry, and maple with out any problems at all. Very little in the way of bandsaw marks too. I've cut ~1/8 x 8 or 9" with out trouble. It just needs to be set up good and take it slow and easy.
It could always use more power I suppose, and maybe you are just talking about cutting wet logs with it, I don't know. I just wanted to pass along that bandsaw can work nicely with the riser kit.
Joe
(running away now...)
>I agree with all of the above. I have the 'gray' version that shall remain nameless, but they are very useful to a turner, especially with the riser block and a narrow coarse blade.
I have a homemade circle cutting jig for mine but find it to be difficlut sometimes, depemding on the blade. If I have a "straigt" cutting blade I use the jig to just push the piece through straight, over and over and lop off corners until I have the thing nearly round. I tend to leave a half inch 3tpi blade on mine as the default and if I am preping a few blanks I would rather hack off the corners than change the blade for the circle cutting ability.
I am not sure about the power upgrade. Mine has a 10 amp motor (3/4hp?). I get along fine with it, but have never had the experience of a 1 1/2. Also, I added band rollers and a carter release lever. If you are adding Carter guides, a Carter blade release, a bigger motor and a riser block, you might want to look at a bigger saw. Some of these accessories are enough to make you think you bought a radio and then bought the car to go with it.
Your level of expectation rises. Now that I have one bandsaw, I wish I had several more. One for circles and intricate work, one for ripping and perhaps another for resawing. Hmmm! Where is that lottery ticket?
I'm sure there are more of here with 14" bandsaws with and without riser blocks than anything else and we get along quite nicely. You can accesorize later.
Peter Toch
>I would suggest you take a hard look at the new Rikon 14" Deluxe bandsaw. It has a 1-1/2 hp motor which is a very definite advantage in cutting large bowl blanks, especially when the wood is wet and wants to bind on the blade. It also has 13"+ under the blade guides, a good sized table, and good dust collection. It too is available at Woodcraft. I don't easily get impressed by new tools, this one impresses me.
Peter
Pat Taylor
>That 13" capacity looks great, but the price reflects it! I hadn't seen that one, but I'll keep it in mind. Thanks.
Steve Kubien
Steve Kubien
>Hi Pat,
I have a really great 15" General (model 590) and my only issue with it is the 6" height capacity. If you opt for the Jet, do as others have suggested and get the riser. I don't know what the $$$ of the riser is but you can always add it later. WIsh I could put a riser on my General but it is a one-piece cast iron frame.
Cheers,
Steve Kubien
Ajax, Ontario
>For cutting green wood I don't like the Carter guides. Mine get all fouled up with resin on the outer surface and it's hard to clean them.
rj anema
>I don't know if there is a Woodcraft near you. They have a Powermatic 14 inch saw with a 1 1/2 hp motor on sale this month. Plus, they are throwing in a free riser which should increase resaw capacity to 12". Woodcraft frequently has a few models on hand in their classrooms so you might get to try them out if you are really interested.
DavePowers
>You should call the Jet factory and talk to a tech. I was looking at a 1/2 hp with a 6 in resaw the model below yours. Asked the tech if it would handle resawing oak or walnut that size and he said not very well and I would have to be careful not to burn the motor up, so I am still looking.
Dave
