turned chess pieces
kyle romick
>Hi, there I am making a shaker style chess table and I am looking to see if any one has plans for turning the chess pieces or any suggestions on how I should make them
all comments are appriciated
thanks,
Kyle
turned chess pieces
kyle romick
thanks,
Kyle
Re: turned chess pieces
Jeff Myroup
>Check out the book:
Turned Chessman by Mike Darlow
Jeff
I turned this set a couple years ago. *LINK*
Dave Smith, Longview, WA
>Hi Kyle,
I used the design from Wood Turning on Line. Link below. I changed the size using a copy machine.
Dave Smith
Still hiding in Longview, WA.
http://www.shopsmithhandson.com/archives/nov_dec00/html/money_maker.htm
>Many years ago when I was a kid I started a set. Not too much trouble with the rooks and pawns and other "round" pieces but I tried carving the knights to look like horses heads. They turned out looking like German Shepards. Not good.
Since then someone suggested a completley different approach. Glue up a hexagon or octagon of alternatine pieces of light and dark wood to form a piece big enough for an eight or nine inch cirlce. Mount it and turn it so that it has the profile of the horse head and then slice it in to segments and glue them onto turned bases. (Think of the rim of a pie tin, but sculpted like a horse's head.) You could make a light one and a dark one, or you could do the alternating sections and get both out of one turning.
Once they are cut apart, you could "improve" the appearance with a little sanding and carving, but In my case I should keep the carving to aminimum or we will be back to the dogs again.
