screw size
screw size
screw size
Lester Gillett/Independence Mo
>I have the Nova Midi chuck and want to use the wormscrew but need
to know what size hold to drill in the blank for it. I read the
instruction but no where does it say what size. looked on the web
for help so came here to ask.
Lester
Re: screw size
Re: screw size
>I usually try 3/8", depending on the "hardness" of the wood. If it is a fairly "hard" wood, I sometimes go for a 7/16". But that's me.
Re: screw size
I use 5/16
Carole Valentine
Re: screw size
7mm core size from website or a tad more
Jim Swank
Re: screw size
I use 5/16 also
rj anema
Re: screw size
Re: screw size
Mike from Tn.
>I've got a Nova G3 chuck and the instructions say use a 9/32 for for softwoods and a 5/16 for hardwoods. I used 5/16 on some walnut and wished I'd gone a bit smaller, but I should have made a few more passes on the barkwood also. My Nova's 2wks old now and I absolutly love it.
Re: screw size
Re: screw size
Jennifer@Indy.USA
>Lester,
I use a Stronghold chuck so I'm of no help to you, however, it's better to have a tight fit rather than for the blank to come loose and then not be able to secure it back on. I usually rub a stick of beeswax on the threads of the screw so that it's a bit easier to remove after the blank is round.
Jen
Re: screw size
Re: screw size
>Thanks every one. I think i will use a 5/16 in a scrap wood to see if
thats the size and adjust from there. This is a great site to ask
for help as every one will help you out.
Lester
Re: screw size
Re: screw size
Don in Central Illinois
>I have the same chuck and the same problem. I thought I was overlooking where they told us the drill size. Anyway, I just attended the Woodworkers Woodshow in Collinsville, IL on Saturday and one of the demo's used the worm screw and told us he used 5/16" and it worked fine. At least now, I can start using the worm screw.
