Re: Tool Gloat
RevDoug
>A couple of you asked some specific questions and about a first impression review. Well, let me tell you. For a $1000 lathe it is fantastic. I was like so many that thought that the bottom speed was a touch too fast. Nova advertizes that bottom end is 214. I don't think it is. I'd like to have someone put a gun on it and find out for sure what the speeds are, just for my curiosity if nothing else.
Before this piece of maple burl I mounted an oak burl between centers and the machine had no trouble with it. Speeds seem to be well spaced and I've had no trouble with not being able to find a good speed so far. Still haven't bumped it up to the high end yet though.
The tool rest, banjo, and tail stock are rock steady. I don't know what the problems were with the 3000 exactely, but I have no movement with any of these. All are locking down very solid.
Jorge asked about the legs and if they are solid enough. Oh yeah. One thing that Nova did was to make them of heavy guage steel and hollow. If one felt the need the legs could be filled with lead, sand, or cement. The feed are adjustable and lock in place well.
A couple of suggestions I would make to anyone who is buying one. First, let the store assemble it for you. It is not a hard process, but there are a few tricks to it that the instructions don't tell you about. Yes, I read the instructions. I don't like haveing to redo.
Second, whether you assemble or the store does, check the set screws on the pullies. Both of mine were loose and need major adjustment. In fact, you will want to go over all the screws and connections with a fine tooth comb. Make sure they are tight and secure.
Third, if you put it together yourself, watch the direction the legs are mounted. They are cut and designed to go in a specific direction. Let me tell you from experience, it is easy to get them backwards or on the wrong side. Not sure you can tell from the pic, but the legs under my head stock are backwards. I've got to change them. Even so, they are rock solid.
All in all I would say that for a $1000, 350# lathe it does more than I would have expected. You can see from my pic that it runs true and straight. First thing LOML said when I showed her the maple was "It's nice and even." She was used to seeing larger pieces I've done on the ShopSmith having a thick and a thin side. Would I buy it again? YOU BET! THIS LATHE IS GREAT!
Turn 'em round,
