A55 Smoothing Plane
Mulberry Hollow Form
gil jones
>Mulberry HF, with an Walnut collar. A coat of Deft, buffed, and waxed.
3" wide x 1.25" hi. The foot needs to be shortened by 6mm, but there is not enough wood left inside. Any of your comments are welcome.
Gil
Re: Mulberry Hollow Form
Mike Rubes, Apex, NC
>Hi Gil,
That's really a wonderful piece! I don't know if you intended the "flying saucer" effect or not, but I think it is very well done! I like the big collar.
Thanks for the pic,
Mike
A Sunday afternoon turning in Apex, NC
Ruth Niles
>Gil, that's a very nicely done hollow form. I don't know if or how you could do this but if you had a separation line, groove, burned line, something right where the form curves out to the foot, it would make the foot look like an "artistic design feature". Or if you could get it on the lathe, wrapped in protective covering (!) and make the foot a bead, it would reflect the collar and look like a natural.
Just some thoughts. Don't know how I'd do any of these suggestions but you probably have more talent than I do along those lines.
Thanks Ruth and Mike!
gil jones
>Mike, the UFO look was not intended, though I see what you mean.
Ruth, it is going into my donut chuck for a bit of podiatry surgery, and I like your idea about the foot bead. We shall see, as there is not much wood thickness to play with. I may have a funnel if I remove too much (Won�t be my first funnel).
Gil
Glenn Hodges, Nashville, GA
>Gil, I like this one. The form and finish make it an exciting piece.
Thanks Glenn
Gil Jones, Lake Seminole, Georgia
Ron McKinley
>I like the UFO look since I've done a few of them. I guess I was inspired by flying into the base at Roswell, NM when I was in pilot training from a nearby base in Texas. I agree that the base could be reduced. Actually, blending the curve into the base would practically eliminate it.......Ron
