Re: Help with Freeform bowl *LINK*
bowlman
>Assuming you have a lathe capable of handling an out of round piece as large as this is, here is what I would do (and have done 100's of these and they are still such a thrill to make):
1. Use the surface you pictured as the "top"
2. Mount the blank between centers and turn a spigot on the reverse side.
3. Attach to lathe using reverse side with newly formed spigot. I prefer to use a chuck that holds onto a pre-formed spigot ot foot. Don't make the spigot too small. Use the largest jaws you have. If this piece is greater than 12 or 14 inches, I'd recommend a #3 jaws on a Stronghold chuck.
3A. Another option: Given that the burl is dry, if you are careful, you could use the chuck expanding into a recess, rather than contracting on a spigot.
4. Turn as large and as deep a recess as you want without turning through all that beautiful grain and character. You may want to make a bead or other rim detail just outside the edge of the bowl depression. See some of Jennifer Shirley's work for examples, or go to my home page at the url provided .. look under bowls in the index (I think).
5. I would use something like Bush Oil, or perhaps Rocklers Wipe On Polyurethane, or a wipe on poly gel. You want to highlight that grain rather than hide it. Also, don't make the "dish" too big, let some of the edges remain as a frame for the grain you select as the "bowl".
6. Price it accordingly ... start high, work down is better than starting low and finding out later that you shoulda charged more ... assuming you would even consider such a thing.
7. Good luck
8. Have fun!
Dick Gerard's (aka bowlman) Home page
