Turning frozen wood
Dawn Adams
>I have no more wood left in the shop. I do, however, have a frozen root just outside the door. I want to turn!!! Has anyone ever turned frozen wood? Any comments or suggestions would be appreciated.
Turning frozen wood
Dawn Adams
Re: Turning frozen wood
Doug Thompson near Cleveland
>Dawn,
Frozen wood turns the same as green except the shavings are cold on the hand. I wear a glove when roughing a blank, the exchange turning was done from frozen wood.
Go for it,
Doug
Ron in Drums PA
>Yup, it was freshly cut too.
Frozen shavings hurt, wear a face shield and gloves (just be careful with the gloves). You might even want to wear a second shirt.
Otherwise it turns wonderfully, maybe even better than green wood that is not frozen.
Dawn Adams
>This frozen chunk is a hickory root (with incredible spalting) and it is turning like concrete. I can only make a few cuts with the gouge and it is dull as a butter knife. Any suggestions? Is hickory root tough to turn?
joaz
>Most roots are tough. Hickory for sure. What's the rush?
Let it thaw and warm up and then try again.
>I NEED to say this... You don't have the right tools!
Bill Grumbine (Kutztown PA)
>Dawn, Ijust got home from Woodcraft (Allentown, not Towson) teaching six newbies to turn with frozen wood. It cuts about the same, although if it is wet, it won't start to sling water until it starts to thaw. Hickory is pretty tough, so just keep sharpening, and hoping for spring!
Bill
Great for some things
Brad Vietje
>I'm with Ron -- in some ways it can be better than warm green wood. Its especially good for getting a clean cut on a softer, or more difficult wood. Basswood is one example -- sometimes hard to get a good finish off the tool, but turning it frozen can help a lot. That may not help much in Florida or Texas, but up here its easy -- my freezer is 15 acres.
Safe spinning,
Brad Vietje
Newbury, VT
Sawing frozen wood
Barbara Gill, Remlik VA
>I have never turned frozen wood but I have sawn some with my Wood-Mizer. It will dull the tools faster than green. Sharpen frequently. Frozen hickory root can present a number of problems including a really hard wood to start with and possibly dirt. All will dull the tool quickly.
