Alabaster sources
Alabaster sources
Alabaster sources
Georg Waldhof
>Anyone in the collective ever turn alabaster? Where can one find large blocks of the stuff? Any problems or issues one needs to be aware of before starting in with a chisel?
Thanks
G.
Re: Alabaster sources
More alabaster questions
>I picked up a piece about 3 1/2" in diameter by about 5" tall at my local Dick Blick store for really cheap -- about 5 bucks as I recall. I haven't figured out how to chuck it though, as I would imagine that any lopsided clamping force might break the irregular form. I thought about just pushing the piece into an open chuck with a v-point tailstock center and then turning a spigot on the end, but then how to cushion it when clamping into the chuck? Is this a good case for making a hose-clamp type spigot chuck (pardon my nomenclature)? Maybe with a dovetail profile to it for safety?
And, when turning, I'd imagine that it would be better to use scraping tools than cutting tools. Am I right?
And for gluing rims or feet on it, what kind of prep and what kind of adhesive?
Ellis Walentine, Host
Re: Alabaster sources  *LINK*
Troy German
Alabaster
Troy German
>The site above has some great info on turning alabaster and a link to Max Krimmal's site with more info. His tutorial seems aspecially good.
They also will cut the alabaster into rounds for a small fee before shipping.
Troy
joaz
>This stuff is very slippery. Be careful when walking on it. And suit up really well. Scraper's only.
http://www.maine-web.com/woodturning
Dale Cook
>I've used Colorado alabaster supply for both Colorado and Italian alabaster and am very happy with it. You use scrapers when turning and it sands very nice. I use weldbond glue for wood rims or bases. If it looks like a crack or fracture use thin super glue. Good luck!
dwr
>Georg,
Max Krimmel has a fabulous site about turning Alabaster, along with an extensive gallery section. Well worth the time to read!
Dave
Max Krimmel Alabaster Tutorials
Re: More alabaster questions
Bob Way, Canton, MI
>I turn alabaster. It can be mounted to the lathe in a couple of ways. Most common is to use a pin chuck, but pin jaws also work as does a glue block attached with either Weldbond or epoxy. You could mount it in your chuck as you are suggesting with the tailstock center to support, but you'd want to make sure the edge/face in the tailstock is fairly flat and square. A typical spigot may not work for holding because it is easy to crush the stone or crumble it under the pressure from tightening the spigot in the chuck.
Definitely scraping tools. The typical high speed steel tools work, but the alabaster will almost immediately dull the tool and the edge will be knocked off. I just made several carbide tipped tools for turning alabaster, and would be happy to show what I did with common materials, and no tool making ability to speak of. There is no grain to the alabaster, so good news is no catches. Tool is presented at, or a little below center. Speed is 40 to 200 rpm starting out, although it can be stepped up a bit once the project is well under way. Stop often to check for cracks in the stone which is a common occurence. They can be treated with CA.
Most rims and feet are segmented...8 segments is typical. The stone doesn't move with seasonal changes, whereas the wood does. The rims/feet can be attached with weldbond or epoxy, and a tenon is typical construction.
Max Krimmel's site has undoubtedly the best description of the process and is well worth the read. There is also a Stoneturner's group with several informational files and links to sources.
Bob Way
Canton, MI
Bob Way, Canton, MI
>In addition to Colorado Alabaster, there is:
Flatlanders at flatlandersculpture.com
Montoya at montoyasculpture.com
The Compleat Sculpter at sculpt.com
Utah Alabaster Supply at utahalabastersupply.net
By all means, Max Krimmel's site. Brad Tallis also has a good site.
Scrapers only. High speed steel works, but be prepared to renew the edges. Carbide is better. Slow speeds. Stop often to check for cracks, and treat with CA glue. It is a messy turning experience for sure.
Bob Way
Canton, MI.
Question
Ron in Drums PA
>I've been reading Max's website this morning with interest. I do have one question.
Both of you mention wood rims and bases. Is this for aesthetics or does it serve a propose?
Funny you should ask
Bob Way, Canton, MI
>Ron, I asked a similar question a couple of years ago on the Stoneturner's forum, and Max was kind enough to respond. I've included his entire response, and I apologize for it being a bit long, but I found it a really helpful answer to the question. I don't know if the Guy Michaels link is current, since it didn't work for me this morning, but I have seen his site recently and know he still has one.
"Hi Bob,
Let's start with a bit of history, the root of the wood rims and bases was function. I needed
an easy way to mount the stone to the lathe. Rather than turn off a waste block thick
enough to put screws into, I glued a thin piece of wood to the stone and taped that to a
thicker, screwable piece of wood. Well, there it was, stuck on the bottom of the bowl, why
not make a base out of it. I soon realized I needed a base anyway since the stone was soft
enough that just setting it down on a table would eventually wear it out. The rim idea
came after my second and third attempts broke apart while turning. I had used a wood rim
to stabilize my segmented wood turnings so I tried it on stone and it worked. Rims also
take a beating if you use the bowl for anything other than looking at, so that problem got
solved too.
The next question was the same as yours, what kind of wood to use? I went through quite
a few fairly quickly, many of those I didn't even have to try out to eliminate. Appearance
was a significant selection criteria but other important ones were, availability,
colorfastness, glue-ability, and porosity. I ended up with three "best" choices, used as is
appropriate visually. They are: for pinkish stone Bloodwood (Satine, Brosimum paraense),
for whitish stone Ebony (not Macasar), and for brownish stone South American Walnut (has
other names I can't recall). As far as I know Bloodwood is the only hard, red wood that
doesn't lose it's redness when exposed to light. It also has a grain structure that doesn't
collect the stone dust. Ebony is black and black goes with just about anything (Macasar
Ebony is striped with brown). The South American Walnut is dark brown (English Walnut
would probably also work for a dark brown wood). I occasionally use Holly or Maple when I
want to add my own color to the wood.
There is another way to think about this though. Check out Guy Michaels website and see
what he does, (http://alabasterbyguymichaels.com). Guy's approach views the rim as a
decorative element on its own. (I think of it more as a frame �the stone ends here). On
the other end of the continuum, I would love to find a wood that would disappear next to
the stone, something that would provide all the function but none of the contrast."
Thanks, Bob
>Lots of good info in your post. I also checked out Krimmel's site and was amazed at the diversity of form and color and texture of his work. I haven't had a chance to dig into his process talk yet, but you bet I will.
Thank you
Ron in Drums PA
>What a wealth of information, Thanks Bob
Georg Waldhof
>Wow! Many thanks to all - this is excellent information and extremely helpful.
I'll be chopping rock before the next new moon!
. . . or not.
Either way, its much appreciated and I'm inspired.
George
