Re: first time turning
David Breth
>It isn't so much doing something wrong as it is learning what to do. Sounds like you are working wtih a piece of wood that is square-shaped. I'm going to assume you are using a bowl or roughing gouge. Here are some hints
1) Sometimes (ok, frequently) it is better to use a bandsaw to knock the corners off first. Easier on you, the lathe, the tools, the toolrest, the wood, and reduces the possibility of a giant corner popping off the wood and into you.
2) Wear a faceshield.
3) Tool may not be sharp enough. Sharpening is a topic unto itself. Lathe speed helps, but it won't cure a dull tool. If you are working a square piece, you don't want to get too crazy with the speed, because improper presentation of the tool to the work can cause a lot of bouncing, bamming, and an unsafe condition, and you haven't got a level of experience to let 'er rip. General rule would be never to exceed a speed that you feel comfortable with.
4) You may not be presenting the bevel of the tool to the work. This is really difficult to explain, I'll try but other people will do FAR better at it. When you look at the tool in profile, you'll see that the cutting edge has a "flat" on the bottom, aka the bevel, or cutting edge. As you raise/lower the handle of the tool, and therefore change the way the cutting edge is presented to the wood, you'll see it cut differently - some angles it will just beat the wood to death, producing dust, chunks, or nothing at all, but as you near the bevel angle, you'll start to get chips that look like something, and you'll make progress on the wood. With a square piece of wood, it isn't always easy to know if you are "riding the bevel", but as the wood gets rounder, if you are riding that edge, you'll start to get nice long shavings.
5) Height of the toolrest. You may be too high or low to present the bevel properly to the wood. If it were me, I'd recommend putting the toolrest at about the same heigh as the center point of the headstock and go from there.
6) Proximity of toolrest to wood. You want to be as close to the wood as you can get (and confirm that the wood can revolve without hitting the toolrest before firing it up). This will minimize bouncing, flexing, etc., and allow you a more steady cut once you do find the bevel to ride.
6) If you've got somebody near you who can help with hands on, or a turning club nearby, it is super-valuable. An hour of hands on help can go a very, very long way to helping you get your feet, and can help you make sure you're working in a safe way.
My 2-cents, but you've got change coming.
David B.
