REAL MILK PAINT
Buffing questions
Buffing questions
Buffing questions
Dawn Adams
>Yesterday I was buffing a few bowls and hollow forms and I have a few questions.
First - is there a way to buff small grooves/lines. The area around these would be shiny, but the shine would not carry down into the small recessed sections (1/16" wide)
Second - oops, I was not thinking and used the Tripoli on my Wax buffer. How do I make sure all of it is removed before I use the wax again.
Third - just a funny aside. It has been so dry and cold here that the friction of the buffing wheel was causing me to become electricaly charged and I kept shocking myself when I touched the lathe. A few times I could see a small spark jump from me to the lathe. Maybe I need to ground myself.
Thanks in advance for any input.
Re: Buffing questions
Rick Allen
>first slow the wheel down can help get into small contours also try a different angle. Results are not promising.
Second You can try a hacksaw blade to run the wheel against. A new wheel is about $16 from Beale
Third I had a BUNCH of little marks on my belly where the spark went through my shirts as I leaned towards the lathe. I try to keet one hand on bare metal to maintain a dischage.
Re: Buffing questions *LINK*
gil jones
>ENCO has a buff rake ($12.99) on page 79 of their Hot Deals Flyer. See link, and go to the page.
As for static shocks, I suppose you could go to Radio Shack, and get an anti-static strap that is use to bleed off static buildup in the body when working on computers and other sensitive electronic equipment. You would need to be very careful not to get it caught in the buffing wheel.
Gil
http://www.use-enco.com/CGI/INPAGE?DCMP=EMC-880500&PMPAGE=/Specials/brochures.html&catalog_name=february2007&rfx_page=1
Make that PAGE 75 in ENCO flyer
gil jones
A Shocking Experience.....
Dave Belser
>Dawn, I don't know where you are but your right about it being dry! It's been so cold and dry here for that last 2 weeks that the occasional static sparks from my buffing wheel have become down right annoying. I mean big fat mean sparks that make you jump back! It got so bad that I finally solved the problem with a 6' length of light gage speaker wire (20 gage?). I striped both ends and wrapped one around part of the lathe. A wrap the other striped end (loosely) around my pinky on my left hand when I buff - problem solved.
A couple of points: wire gage doesn't really matter just find something flexible and light. If you wrap it around any part of your hands, make sure for safetys sake that it will come off real easy. As I said using the pinky of my left hand keeps it out of the way. You could also just stick the end inside of your sock or shoe etc. to keep it more out of the way. This morning I was down in the shop before breakfast and picked up something to buff, I didn't use the wire and didn't get shocked, then I realised that I was standing barefoot on the concrete floor, and hence was grounded - but I wouldn't recommend working barefoot as a habit :)
- Dave
jared
>I buffed four bowls yesterday and had exactly the same experience. I was zapping myself all the time. I was wearing sorel boots, with the rubber soles so there was no way the electric charge could bleed off through them. It has been cold for awhile here in Iowa so the heater has been running for a while and everything is dried out. I guess the buffing wheels must be the ideal thing to build up a good charge. Maybe this could come close to the perpetual motion machine. You run electricity in to the lathe that the buffing wheels are mounted on and then you could sell back the static electricity that is generated. The way it felt, there should have been sufficient quantity to resell. Jared
Paul Porter
Get yourself a brake-away...
Paul Porter
>...static strap. I think Radio Shack carries them.
Re: A Shocking Experience.....
Bob Fawcett
>You could use a static strap used for electronics. These are made of lightweight flat material, usually paper impregnated with carbon to carry the charge. They are frequently shipped in the package with replacement computer parts. If you know someone in that business, they may be able to supply a few. If not you can probably buy one at Radio Shack or similar store. This would be a good alternative, if it ever snagged on a spinning buff it would break away easily and not cause injury.
>Do be careful about the ground idea. If a buffing wheel were to catch a wire it would turn into a "weed eater" instantly. Someone here posted about turning a bowl and trying to glue a wire into the rim. Partially came loose and cut them several times.
PS Maybe you could......
>use one of those grounding straps I see on cars. It hangs down and hits the street once in a while. You could make yourself ankle braclet with a piece that dragged on the floor. That would be better than standing in my shop in bare feet. I would freeze to the floor and have to buff a while to work up enough enregy to melt myself loose.
