Follow up to my Spindle question yesterday
Joe in a Cleveland suburb
>Hello again.
So I read all your responses from yesterday regarding proper use of a skew chisel. That for all the responses by the way.
I went home last night and put all your advice to work. I had a lot better results. The one suggestion that I think helped quite a bit was to slow the lathe down. I put it at its slowest speed. That also lowered the intimidation factor a bit... I don't know how you people stand behind those massive chunks of logs when making big bowls... yikes.
Anyway, the handle below will do. I tried doing a couple beads and stuff - it's all for learning. It's almost done. I got a little excited last night and removed it from the lathe before I was ready to, but it's getting there. I have another one to make yet. It will be made from walnut. I have two Doug Thompson bowl gouges to put into these handles. I'm dying to give that a try!
I've used this little lathe more in the past week than I have the entire 4'ish years I've owned it. I really need to build a dedicated stand/table for it. Using it on my work bench has it up way too high and it takes up too much room. It's all coming together though. Soon I will be able to take a stab at a bowl. Well, I do have other stuff I gotta get done first too. Like the dreaded MIL table...
Thanks for all the help! I'm sorry, but I'll be back...
Joe
Here's the whole thing -
This is towards the working end. I have some small brass fittings that will be used for the ferrel.
Re: Follow up to my Spindle question yesterday
Brad Vietje
Congrats -- Looks great !
Brad Vietje
Bob Fawcett
>Looks great Joe.
I built a stand for my Jet with construction lumber. Its basically an oversized sawhorse. The top of the horse is a piece of 3/4" plywood. I ripped a 15 degree angle down the edge of 2 2x6s. These go along the edges of the 3/4" ply. Glue and screw the parts together. Size it to fit the bottom of your lathe. Attach 2x4s to the corners for legs and brace as needed.
I cut a /\ piece to fit the gap between the legs on each end and built a shelf between the legs about halfway to the floor. I also put a 2x4 across the bottom of the legs on each end /_\ .
This makes a sturdy stand that is easy and cheap to build. Load the shelf with sand bags if you want more wieght.
