We value your privacy.
>I did the necessary filing of one of the pivot alignment slots and shimmed the headstock up by .025" using the white plastic shim stock from McMaster-Carr. The vertical alignment was off by ~.022", but all I had was .020" and .025" plastic shim stock. After locking everything down the diff. is .0016". This will do for me. Jamie is correct about these pivoting headstocks and I won't be rotating this one anytime soon.
This day was a bit bad because we had a DISH tech here upgrading our system (trust me not a gloat) and he cut the wrong wire too short which lead to a lot of extra work. On top of that my wife had a heating/cooling guy come in to measure and give a pitch and quote on a new heater and AC.
>After aligning and locking everything down I zeroed the dial indicator on this relief in my M2 to M33 adapter. The indicator is metric and each division is .01mm.
>Here is the reading I got on the same relief area and the adapter in the tailstock. It's .04mm (.0016") lower than the headstock. Pretty good for my level of turning ability. Now to weigh the base down to turn some wood.
I have an older (1998?, Blue-ish) 1236 that I only use for teaching and buffing these days, but it was my principal lathe for about 4 years. Looks like you've got yours tuned up and ready to roll !
The need for exact alignment of head & tail will depend on what you make with it, and the degree of precision needed for the job. For bowls, and most "faceplate" turning, it doesn't seem to matter at all (even though I start every bowl between centers), but can become important for fitted parts, and delicate centerwork. Wood is not a perfectly stable medium, so you can only get so much precision out of it.
In my case, there is so much slop in the 1236 tailstock that the precise position of the headstock wasn't the biggest issue. The tailstock just wasn't very often inclined to lock down in the same position, so having one end fixed precisely didn't seem to matter much. With that double ended Morse taper, you should be able to rotate your headstock as needed, and get them back pretty darned close. I often rotated the headstock to about 30 degrees or so -- no detent there -- for boring out hollow forms. Only once did I turn the headstock 90 degrees to make a platter, and found that the banjo and toolrest setup wasn't up to much heavy work. BTW: chuck out that odd-shaped toolrest outrigger -- those things are dangerous !
Its a good, stable lathe to learn on, and you can make a lot of things with it and get a lifetime of pleasure from it -- however, precise machining it just ain't known for.
>... congrats, by the way on getting the alignment very near perfect.
no hijack intended, just thought some might see the humor in a recent DISH NETWORK upgrade by a very incompetent installer .. At my mother's house, the tech arrived at 5:00pm .. TEN HOURS LATER!! (3:00am!) he is finished with two televisions, and cannot get the third to work. No, he did not have to wire the entire house, use existing RG59 (her TVs are junk anyhow) ... Oh, I got the third TV working in five minutes (tune to channel 73. Done. Oh well .. back to woodturning.
