We value your privacy.
>Over the weekend I purchased a used "Jet 1236" lathe that is in almost as new condition for the price of a Jet Midi. The lathe came with a no-name 8 piece set of turning tools. While I already have a 12" cap. lathe in an old school Atlas lathe, I decided to get this lathe to get a little more modern machine that has some components in common with my Jet Midi. Plus the price seemed right. I still won't give up my Craigslist search for a Powermatic or Oneway at an almost give-away price from a disgruntled spouse. Sadly, turners don't seem to disgruntle any spouses..:-)
>After assembling the lathe in my garage I checked the headstock to tailstock alignment. You can see in the picture that things aren't right. Man, it is off by about .080" horiz. and close to .040" vertically. Yikes! This lathe has the pivoting headstock feature for outboard turning so it makes correcting this problem more difficult. Right now if I bias the headstock to correct the horizontal alignment, the locking pin doesn't engage. I can file the slot on the table casting, that the index pin engages, to provide some extra slop, but the vertical alignment is going to be a problem.
If I shim the gap between headstock and bed mating surface I don't think the shim will survive a lot of wear from pivoting the headstock. On the other hand how often will I be pivoting the headstock for an outboard turning of some type?
I'm not trying to knock this product as I realize that for the pricepoint of this lathe, adding the pivoting feature, was surely going to throw a wrench into the manufacturing tolerance buildup of this machine. This is just something we have to check for and deal with in this price range of a lathe. When I get this fixed I'll post a picture of my properly aligned 1236.
>I wouldn't give up on the lathe. I would suspect the drive center and the live center before counting the lathe as the problem. I like to look for the problem to be in the least expensive.
The procedure I use to check alignment is:
1. Clean and inspect the taper in the headstock and the tailstock.
2. Mount a hunk of wood between center and snug up on the tailstock.
3. Remove the wood slide the tailstock up to check alignment again. Make sure you tighten down the tailstock when you check the alignment.
4. If alignment is still off then try different centers in the headstock and tailstock with the same procedure.
5. If you don't have access to other centers try the live center in the headstock and the drive center in the tailstock.
>Yes, I was looking and hoping for something easy too. Thankyou for the measurement/alignment suggestions. In this case I'll be using the tailstock as the datuum. I have a spare M2 to M3 taper adapter that I will use as a guide pin to help align things up.
I'm still having 2nd thoughts on keeping this lathe, because even though I'm steping up to a Reeve's drive, I'm losing out on an indexed spindle like my old lathe has. And...can any of the new, boxy looking CAD designed iron beat the looks of the hand drawn, flowing curve, art deco style of that old Atlas?
>.. that a rotating headstock is a negative feature. Adjust it however necessary, then never move it if possible, else you'll have to go thru the same alignment each time.
Just a quick note: you do have an indexed spindle there, but not a real precise one. The two holes in the casting near the spindle are recepticles for the knockout bar so you can lock the headstock and remove/replace faceplates, chucks, etc.... If you need two hands, you have to hold the bar in with your belly ! These holes double as a crude indexing feature. I haven't used this in a few months, but I think there are 12 holes in the spindle that can mate up with the two casting holes for a 24-position index, though there's enough slop that you have to keep the knockout bar in the same relative position at each stop to get any real accuracy out of it.
