Reverse chucking bowls??
Pat Taylor
>The weak point in my bowl finishing is the bottom/foot. After hollowing, I've been either reverse chucking with a jamb, supported by the tailstock, or parting off above the chuck. Neither method allows free access to the base for a nice finish and shape. I can chisel the bit that was blocked by the tailstock and hand-finish, but I'd like access to the whole bottom while it's on the lathe. So... What do you folks use? Vacuum chuck? Cole jaws? I've read a bunch about it, but I'm curious what you guys do in practice.
Thanks,
Pat
Re: Reverse chucking bowls??
Vacuum chuck...
Peter Teubel
>I have 2 sizes of cole jaws, but rarely use them.
robert davis
>longworth chuck,see archives
Barbara Gill, Remlik VA
>I use the vacuum for everything except the pieces that let too much air through. Then it is either the Cole or jamb.
RevDoug
>I have often used a donut chuck. Works great. In fact, I need to go get more plywood to make a new one for my new Nova 1624.
Turn 'em round,
I've used the cole jaws a few times....
Bert
>but for me, the jam chuck and a little chisel clean up is just faster. Plus I think it's nice to do a little "manual" labor on each piece. Keeps me close to the wood and the grain etc.
Bart Rhoads
>I use a vacume chuck anytime possible. Other times I use a jam chuck. Once you use a vacume chuck you will wonder how you did with out it.
Russ Babbitt Jr.
>I have cole jaws and vacuum chucks. I usually reach for the vacuum chucks. If money is an issue cole jaws, longworth or donut chucks are good options.
Cyril Griesbach
>Pat,
Most of my bowl bottoms a just slight concave. I often hold the bowl against a "sort of" jam chuck. Really a tappered block of wood on a dedicated face plate. I use a 1/4" gouge to finish as much as I can and then use a narrow parting tool to remove as much of the "pip" as I can. Then, with the lathe turning about 100RPM I take a carvers spoon gouge and apply gentle pressure against the "pip" at the bowl bottom. When the pip stops rotating you've severed it and as you gently remove the spoon gouge everything still will hold against the jam chuck. Stop the lathe, hold the bowl and slide the tailstock back to remove the bowl. Then sand as necessary. Don't but that spoon gouge in twice or it will all come loose. DAMHIKT
Cyril
Bob Moffett
Bob Moffett
>I use a vacuum chuck whenever possible. If the piece has holes in it so I can't use vacuum, I use a jam chuck made on a decicated face plate and a 4" schedule 40 pipe coupling (avaliable at Lowes or Home Depot or any other place that sell plastic plumbing pipe).
Re: Reverse chucking bowls?? *LINK*
>Pat Check out the link below and go to "reverse turning bowls" You will find a lot of choices. The only thing I don't have on there yet is the Longworth chuck.
http://www.cumberlandwoodturners.com/tips.asp
Bill Grumbine (Kutztown PA)
>Pat, I do just like Cyril has described. Most of what I have been turning lately won't fit on cole jaws or be held with a vacuum anyway. At a recent meeting, one of the other guys asked me if I ever turned anything that didn't have holes or cracks in it!
Bill
Bill Howatt
>I used a compression (donut) chuck initially for a few years. Once I got my vacuum chuck system bought/made it is vacuum all the time unless the piece won't hold a vacuum. If I can't use the vacuum, now I often just put the bowl over the drum chuck (pump off) and bring up the TS and finish it down to the little nub which I remove off the lathe.
While the compression chuck is not as convenient I must say that it did work well and is a lot easier to make than a Longworth.
Bill
>I have a vacuum chuck but don't use it for shaping the bottom of the bowl. At least not much. I find it tough to center the bowl up reliably. I use the vacuum shuck a lot for sanding and finishing though.
I made a set of "grippers" for my Cole jaws that are metal straps bent slightly past 90 degrees. I hold the straps to the jaws with the original rubber buttons. They are about three inches long and extend the reach of the Cole jaws out to the full 16" swing of the lathe. They work much better than the rubber buttons. When I turn a bowl I rough the outside, then finish the inside and the top inch or two of the outside (to give the grippers a finished surface to hold onto). Then reverse it into the Cole jaws and finish roughing and sanding the rest of the bowl. I have a large pair of "scissor" calipers that allow me to reach between the plates of the Cole jaws to check the thickness all the way to the center of the bottom.
I have also done jamb chucks and cut the nib off the bottom. Sometimes I chuck a sanding disk in the drill press and just set the bowl on the DP table and bring the disk to bear.
Paul Porter
Jam chuck & Masking tape is a quick...
Paul Porter
>...way to be able to turn the bottom of a bowl.
1. Turn the jam chuck to fit the bowl. It doesn't have to be an exact fit.
2. Hold the bowl up against the jam chuck with the tail stock.
3. Wrap masking tape over the bowls edge and around the chuck real tight in a cris-cross motion. Keeping the tape tight is the key to making this work. Use enough tape to feel safe.
4. With the tail stock still in place, start turning the bottom of the bowl until you have a little nub or the center is in the way. Move the tail stock out of the way and take light cuts towards the head stock until the nub is gone. Then take a light cut across the bottom, add a couple of detail lines with a parting tool and sand.
I'll look to see if a have some photos of this method tonight when I get home from work. I use this method when I demo because it's quick and easy.
~Paul
Steven Antonucci
Depends on size-
steve antonucci
>My cole jaws hold up to 11.5" or so. Between 12"-15.5", I'll jam chuck with tailstock support. Above 16", I use a doughnut chuck.
All three work great, with the cole and doughnut chucks giving me full access to the bottom of the bowl. The Jam chuck always leaves a little pip that I remove with a chisel and sand flush.
Steve
Re: Cole jaws don't fit all bowls
Allen Neighbors
>below 9 5/8", so I made a Longworth Chuck. I like it better than the cole jaws. My Longworth is made to fit in a chuck, instead of a faceplate.
I also have a Jam Chuck that uses Rubber Bands to lock the bowl into position. With that I can take some pretty brutal cuts.
Re: Oh yeah,
Mike Hamilton
>Check back through Allen's postings. I made a copy of his rubber band clamp donut chuck. It does a wonderful job for much less money, space and hardware than vacuum. Like all donuts, not good for uneven (like NE) rims, but hey, I'm still practicing fair curves on basic bowls. All it cost was the price of faceplate and some plywood scraps.
Regards,
Mike Hamilton
Plainfield, IN
Dennis in Southern Oregon
>Pat, I use a very low-tech solution. Others mentioned using a jam chuck with tape. Instead of the tape, I use three or four 1-inch dia. fender washers or similar-sized scraps of 1/8 inch plywood. I screw these to the jam chuck next to the edge of the bowl so that one side of each rests against the bowl and the other rests against the jam chuck. The washers are distributed roughly equally around the bowl. If you use fender washers, pad them with a bit of tape to avoid scaring the bowl. If you have a screw gun this is faster than taping the bowl and is more solid. Dennis
Brian Simmons, Heflin, AL
>For small items I try to use the vacuum chuck. When the vacuum chuck won't work I usually reach for the hot glue gun. If the piece is sanded smooth the cold glue can usually be rolled off the wood with finger pressuse. Warming slightly with a heat gun will give better results but only if warmed slightly.
Leo Van Der Loo
It depends on size, shape and where the wind blows
Leo Van Der Loo
>from, I use, Chuck with the regular jaws or the rubber cole jaw bumpers on there, then cloe jaws, vacuum if that's possible, donut type jaws or just wooden faceplates with saran wrap around or some wood blocks screwed on to keep the bowl on, just depend on what it takes, and how I feel, (lazy or not) ;-))
Have fun and take care
Leo Van Der Loo
Darrell Feltmate
>For bowl bottoms I use a sanding pad on a holder on the bowl lathe or the drill press and work the bottom against it, going through the grits until satisfied. I have attached a link to the process. One of these days I need to make a site map. If you follow the tool making links there is also a page on making a set of Cole jaw copies for your chuck.
Sanding a Bottom
Have a link to this rubber-band idea? Thanks..
Pat Taylor
So many great ideas....
Pat Taylor
>Thanks everyone for all the advice! I've got a few new methods to try, and I'm sure I'll find the one(s) that work for me.
Pat
Re: Have a link to this rubber-band idea? Thanks.. *LINK*
Bruce Wiseman
>This is from Keith Tompkins visit to the CICAAW club for a demo, the pic shows a kind of rubber band chuck, not a donut like Mike is talking about but it worked for Keith.
http://www.cicaaw.org/node/view/618
