Second Bowl Gouge?
Second Bowl Gouge?
Second Bowl Gouge?
eric_s
>As I've posted before, I'm a relatively new turner who has garnered a lot of great advice from this forum. I have a mini-lathe that I am turning bowls on - currently I have a 1/2" P&N Bowl gouge, a HD radiused scraper and some smaller scrapers that I use (I use the bowl gouge almost exclusively). As I develop my bowl turning skills I'm wondering what, if any, the next tool purchase should be. I like the look of footed bowls, so I am thinking a smaller 1/4"(?) bowl gouge would allow me to do some finer detail work/embelllishments. Is this a reasonable idea/purchase. Or should I be thinking about another 1/2" or 3/8" gouge with a fingernail style grind? What I use now is pretty close to the factory grind with the wings swept back a little bit .
Thanks,
Eric
Re: Second Bowl Gouge?
Wally Dickerman in Arizona
>A 1/4-inch bowl gouge would be an excellent choice. I use mine a lot. I grind my larger gouges at 60 deg. but I grind my 1/4-incher at 45 deg. I find that it's a more versatile tool with that grind. Great for detail work.
Wally
Greg Haugen (La Crosse, WI.)
>I don't have any experience with a 1/4" but I do have a 3/8" in addition to my 1/2" bowl gouges. I do like the feel of the 3/8 size gouge. From Wally's post a 1/4" does sound like a nice detail gouge. I would suggested finding another turner with these gouges and try them. Especially any gouge with a swept grind if you haven't used one before. It's alway better to "try" anything before you buy it. And if you grind the swept back grind and do not like it you're going to shorten the gouge alot to get back the other grind. Try them out.
Hope it helps,
Greg
Fog Tanner
>Like you I have a 1/2 bowl gouge (actually 4 with differnt grinds) which I use depending on the size of the bowl, I also have several 5/8" and a couple of 3/8". For doing the foot and any sort of beading I use either a 3/8" or 1/2" shallow gouge - depends on the size of the piece. For really small stuff I use a 1/4" shallow gouge. The shallow gouges I use are ground with a thirty degree bevel, much like a detail gouge. I also use a 9/16" shallow gouge for most if not all of the outside shaping of the bowl. Got that from Raffan, cheaper steel and will do the job since the tool rest is always close.
If you are looking for a new gouge, you might want to try one of the ones that Doug Thompson is making. I just got my 5/8" bowl gouge in and it looks great and I plan on getting more. They are the only gouge that I ever bought that came sharpened with a usable grind, and ready to go out of the package. They are made from the same steel as the Glaser A-11 gouges, but a whole lot cheaper in price and a quality item. You can find Doug's e-mail by doing a search through the archives. Doug is also a great guy to do business with.
Russ Babbitt Jr.
>Just because you're working on a bowl the gouge you use does not have to be a bowl gouge. For working on the foot a small spindle gouge can be useful for details.
Thank you
eric_s
>Thank you for the responses. For right now it looks like I'm going with the 1/4" bowl gouge and will try the shallower grind angle. I have a couple of small, roughed out ash bowls that are ready for finish turning that will be good to experiment on.
When I am ready for a bigger gouge I will definitely check out Doug Thompson's offerings.
Hopefully this weekend I will be going to an AAW chapter meeting where I will meet some local turners. Just found out there was a local chapter - up until now I haven't met any other turners in person.
Eric
Where are you located?
Pat Taylor
Re: Where are you located?
eric_s
>Frozen western NY between Buffalo and Rochester.
Re: Second Bowl Gouge? *LINK*
Darrell Feltmate
>Why a bowl gouge? I like an Oland tool or inserted tip tool for faceplate work, especially detail work. Making a family of 3/16", 1/4" and 3/8" Oland tools will likely cost you less than $10.00 and I use mine over my bowl gouges.
Making the Oland Tool
