A burning question
A burning question
A burning question
Troy German
>I would like the next bowl I turn to have a blackened, dimpled exterior. I was practicing dimples with a ball pein hammer last night and am comfortable with that. But how does one scorch the wood? A torch while on the lathe? Friction by letting it rub something while turning?
Scorch first then dimple or dimple then scorch?
Any tips would be greatly appreciated.
Thanks for sharing,
Troy
Re: A burning question
Different Method.
Russ Babbitt Jr.
>Felt tip marker and Foredom burr.
Raymond Overman in SC
>You can also look at black gesso or possibly ebonizing to get a more even black surface. Black lacquer is also an option.
Dick Anderson
>Troy:
There are several ways to blacken the surface of a wood turning. What you use and how you do it depends on the wood and the effect you want to achieve. I have burned with a torch, pyrography pens, soldering iron and gun powder. I have also used acrylic paint, water and alcohol based dyes, felt tip markers and patinating dyes. I'm still experimenting.
If you dimple the wood before torching then the dimpled area does not get burned unless you direct the flame directly into the dimpled area.
If you stain or dye the wood and want to expose natural wood by dimpling then the wood will dictate. That is the dye may penetrate too far to get to natural wood.
Knock on the door, must leave you now.
Dick
Re: A burning question - more info
Dick Anderson
>Troy:
Sorry for the interuption. Friend stopped by to talk woodturning.
On burning with a torch: A ball pein hammer that I'm familiar with will leave fairly large and shallow dents, which will tend to burn same as the surrounding wood. If you stipple the wood with a Dremil or Foredom type tool then the indents will be smaller and they will not be burned unless torch is directed into the indent. By angling the torch in relation to the wood surface there is even less tendency for the indent to burn. Also, to control the burn you can deflect the flame off a metal plate onto the wood, but wear good gloves since the metal gets very hot.
If your hammer produces large and shallow indents (which likely will also burn) then I don't think it matters whether you burn before or after hammering. However, using the hammer after burning will leave a different texture and contrast on the scorched surfaces. If you want the entire surface burned and maintain a similar surface appearance over all then I would use the hammer before burning.
If you are interested in achieving a contrasting coloration other than by burning I can share my experience in that with you. Give me an email on what your trying to achieve.
Dick
Troy German
>Thanks. I'll find some sample pics of what I'm trying for and email you tomorrow. I would do it now but tonight I get to use the lathe.
Thanks again,
Troy
John H. Williams
>Hi!
The RazerTip system includes pens with two or three different sized spherical tips. See http://www.razertip.com/main.htm
With this method, you get the dimple and the blackened surface at the same time.
John H.
