Anchorseal and roughouts
Roger T
>Morning all,
Just came into a monster tree, and have begun the process of breaking it down and roughing down bowls and end grain blanks. This wood is all frozen and heavy. As I have been working this down, I have been throwing them in a pile and at the end of the day, slathering them totally with anchorseal.
Am I asking for trouble here? With all the trapped ice/moisture in the wood? Most recommend to only anchorseal the end grain, but most of these pieces have crotch figure and end grain is everywhere. I have been using the 10% rule for roughouts. With being totally covered is there still a need to paper bag these or can I just put them up on a shelf and let time do the work. With just leaving the anchorseal on the entire piece, roughly how long will it take to eventually end up at equilibrium?
I know, lots of questions, but after all this work I dont want to end up loosing all of this wood.
Lurk mode back on. :P
Roger
Re: Anchorseal and roughouts
Brad Vietje
Not askin' for trouble BUT...
Brad Vietje
>The Anchorseal probably won't dry and make a good seal until it warms a bit. I have gotten an air space under the hardened wax if there was frost/snow on the wood, so I usually warm the wood a little before coating.
In my experience, wood kept frozen will hold up very well, as long as its out of sun (!) and wind. Winter winds around here are really dry (and pretty *$&%*$ harsh the last few days !), and can dehydrate wood even though its frozen. I often toss frozen wood in plastic garbage bags until it just begins to thaw -- then coat them or rough turn them ASAP. If you forget them, you'll be OK for a while, as long as they are still pretty cold, but you can get a slimy, moldy mess if they stay in plastic for too long once thawed.
Safe spinning,
Brad Vietje
Newbury, VT
Leo Van Der Loo
Leo Van Der Loo
>Hi Roger, what kind of wood is the tree ?, what's the climate up there going to be after the frost is gone?.
For now, if the place you keep the roughouts is not real warm and dry, you should be OK, just don't store on high shelves in a heated room, then in a couple of weeks the moisture level in the wood will have subsided enough to have them out of danger and dry just fine.
For how long it is going to take ?, depends on a number of variables, what kind of wood, how thick are the walls, how warm and dry/wet is it, air movement little or none etc.,
Have fun and take care
Leo Van Der Loo
