200+ woodworking book reviews
Termite Tool Advice
Termite Tool Advice
Termite Tool Advice
Curt Stivison
>I have read a couple posts lately about how good a Termite tool works. Is it a tool that a newbie could learn to use without much experience or should I practice more at destroying bowls before I buy one.
Thanks
CW
Re: Termite Tool Advice
Practice more...
Eddie Pacheco, San Jose, Ca.
>I got one of those when I first started turning. It seemed to me that I got a catch when the business end of the termite was NEAR the wood, not even touching. I launched a lot of would be great creations off my lathe with that blasted tool. Last summer, after a lot of tips gleamed here, and learning the art of riding the bevel with my other tools, I used the termite with success on several occasions. I'm not afraid to use it anymore.
Bruce Wiseman
>Well, one of the continuing mistakes I keep making is in thinking that some new tool is going to some how make me into a good turner. I have watched the really good turners and it seems like they use one to maybe three standard tools for everything. Termite tools are pretty specialized and don't do anything that an experienced turner can't do with a bowl gouge. Just my .02
Leo Van Der Loo
The Termite is good for ENDGRAIN wood turning.
Leo Van Der Loo
Here's Some Helpful Information *LINK*
Clem Wixted, Jonesboro, AR
>Click the link below and then click on TOOLS and TIPS on the left of the page. The 5th photo down has a link, THE TERMITE in the text.
Follow the link for some helpful information on using the Termite, it helped me.
Clem
http://www.hdv.net/
Re: Here's Some Helpful Information
Curt Stivison
>That was a neat web site. Thanks Clem
CW
Garrett in Victoria BC
>My experience is that with the Termite, speed, i.e. slower than faster, is a major factor in avoiding catches and achieving good results. The tool can hog off a lot of material through a very small hole, but if you're too aggressive, the ring needs clearing more often as material packs in. Also, remember to clean shavings from inside the vessel or they'll eventually foul the tool.
I thought I'd wasted my money until I slowed the lathe down and concentrated hard on keeping the bevel rubbing. Now I reach for it without hesitation.
Cheers, Garrett
Jimiles
>I use a termite quite a bit:
My 2 cents worth.
Think of a termite as a gouge turned on the side
you have to learn to rub the bevel in a little different way to make it work.
Start with the ring up & down, top at 12:00 bottom at 6:00
slowly move it to the left to contact the wood and at same time begin to rotate it slightly clockwise, so the cutting edge starts to come up until it just begins to cut. Practice just like with a gouge until you get the feel of it. Also as you get the hang of it you have to learn to hold the shaft on the tool rest and leverage the tool slighty into the wood to get a better cut.
I think saying that a termite works best on end grain is really a missunderstanding. Where it really works best is actually side grain.
If hollowing a vessell, drill a hole to bottom and then you can use the termite to do the hollowing by cutting to the side grain.
I have made a 3 foot x 3/4" diam metal bar that the termite fits into end, I can hollow 10 - 12" over the tool rest.
The other challenge is learning to sharpen it. Throw out the stuff that comes with it ( or don't buy ) use a small cone shaped dremel bit to sharpen. you only need to sharpen one side ( opposite top & bottom ) and front end
No, it is not a beginner tool, but a great one to have for some applications, good turning.
Bob Way, Canton, MI
>I used the termite for the first time just a couple of weeks ago. It had been sitting in a drawer because I had heard so many catch and launch stories. That did not happen to me at all. Now, even though I've been turning several years, I'm not a natural at it, so I read the instructions that came with the tool, did a Keith Rowley dry run a couple of times to see what it felt like, then turned the lathe on. It was one of the nicest hollowing experiences I've had.
Can a new turner learn to use it? Absolutely. But, I think a newer turner might want to approach the learning curve by developing a comfort level with the basic tools such as a scraper and a bowl gouge first. The only reason I suggest that is there are some advantages to getting the feel for hollowing in general, and the techniques of scraping, shear scraping, and riding a bevel in particular. My unscientific, personal, thought is having a sense of what those edges and shapes will do, and not do, helps with making good use of the termite, or any specialty tool.
The termite will not replace my scraper or gouge entirely, but it is a very welcome addition to the options I have when approaching a project. Enjoy your turning.
Bob Way
Canton, MI.
Herman de Vries
>Curt, I see that someone has already pointed you to the little tutorial I did on the Termite. I hope it helps.
The Termite is primarily an end grain tool. If you're turning an end grain bowl, then reach for the Termite. It will work with side grain too, but not as effectively, as the long grain can clog the ring more. The main reason the ring clogs is because the tool is not cutting properly. The shavings are supposed to go THROUGH the ring and as long as they do so, the ring stays clear.
Look carefully at the cutter from the side. You will see that it is slightly beveled. That makes one edge more benign, and you can easily rub the bevel with that edge. Turn the tool over and you have much more aggressive tool that you need when you are deep hollowing, or when you want to go across the bottom of the inside of the bowl.
I use the Termite for deep hollowing. I've done up to 26" deep on the inside of a vase with it, using shanks I made myself as you can't buy shanks that big.
Several tips about using the Termite:
1. When you are learning to use it, ALWAYS start the tool with the tip oriented vertically. It will not cut or grab that way. When the cutter contacts the wood, rotate the tool from vertical to about 1:00 to 2:00 o'clock. It should begin to cut. Once it does, more rotation will simply make it more aggressive. Just pull the tool along the cut, towards you. The tool ALWAYS cuts from the center of the piece out. I've learned to cut both ways, but that is not for the faint of heart, and I'm not convinced it saves any time.
2. Play with the speeds. Quite often, slowing the piece down will result in a better cut.
3. Tool height is of utmost importance. As you go deeper into a deep bowl or vase, the tool rest gets raised slightly. That will minutely change the angle of the cutting edge to the wood, and will result in a cleaner and better cut. Raise it too much, and you may be asking for a grab.
4. Be careful placing the tool into a spinning piece and taking it out. Any slight contact with the piece with the cutting tip will cause it to grab - unless you have returned the cutting edge to vertical.
5. Practice on open bowls, end grain, green wood. You will quickly fall in love with the Termite. I introduce it to all my beginning students and they have no trouble with it at all. It is their hollowing tool of choice.
6. Be prepared to be frustrated if you are trying to get a nice smooth pre-sanding surface. Getting a consistent, non-ripply cut, takes practice. The "turner's sway" works, but in reverse, as you are pulling the cut out of the bowl. It's worth practicing, but you may still find yourself reaching for a shear scraper to clean off the ridges.
7. Once you've practiced with the open bowl a bit, concentrate on looking away and go by feel and sound. That is how you use the tool.
To show how effective it is, I recently turned the outside shapes of eight vases, all between 10" to 12" high and 5" to 6" in diameter. The green oak, end grain blanks had tenons on them, and I wanted to rough turn them to about 3/4" thickness to dry. I timed myself on the hollowing. Average time per piece, including mounting the pieces and taking them off the lathe, was 4� to 5 minutes. I was done in 3/4" of an hour. That was to mount them, drill the �" center hole to depth with a lamp auger held with a vise grip, and hollow them out. And I wasn't trying to be deliberately aggressive. The tool will kick you if you get pushy with it.
Hope this helps.
Herm
Herman de Vries
>I forgot the best advice of all. Tuck the handle of the Termite under your arm. You can't control the thing nearly as well with your hands alone. My lathe is set fairly high, and with the big shanks I tuck them under my armpit. For the smaller shanks, hold the shank between your arm and body. Both hands will end up fairly high on the shank. Plunk your body against the lathe and lean over if you need to. It's very, very comfortable.
I've found that most people have difficulty because they are trying to control the tool with their hands and arms alone. Use the body.
Re: Termite Tool Advice *LINK*
Darrell Feltmate
>The Termite is a great tool. It has a learning curve but so does any tool. On the other hand I like to use its precursor, a hook tool. the cuts are the same and there is some video on my site that may help to illustrate the piece at work for you.
Using the Hook Tool
