A55 Smoothing Plane
Question for mini lathe owners
Joe in a Cleveland suburb
>Hi.
Can you tell me about your setup as far as what you have you lathe on? Is it on a stand? Bolted down to a bench?. Any added weight? Those kinds of things.
What about height in relation to your body - where is the center of the item you are turning?
Thanks,
Joe
Re: Question for mini lathe owners
David Breth
>The stock response for lathe height is the center point should be about elbow height. The follow-up response to that is "wherever you find it to be most comfortable."
I'll semi-defer to other people for their mounting methods, other than to say you want to mount it in such a way that you have not compromised your ability to have physical access as you move around, and such that it doesn't have much opportunity to wobble around. I haven't used my mini in a while, but I pretty much had a terrible setup - it was mounted on top of one of those craftsmen portable workbench deals. Height was good for me, but the legs flexed a lot with an unbalanced load.
David B.
>Joe I currently have 4 mini lathes. 3 are on thier own stands mounted about an inch above my elbow height. The 2 jets are on lightweight stands that add weight to after moving. The Nova is on a permanent stand with drawers to hold stuff for that lathe. The Carob-Tec is my traveling lathe. It is on a stand that is 11" tall and sits on folding stand. This makes it easy to haul with me when necessary.
Curt Stivison
>Joe,
I have a Jet mini that I have mounted on a Jet stand. I have not had any trouble with it but I have only been turning about a month. Stand is set as low as it can go, about elbow height.
CW
Bill Youngblood
>Hi Joe,
Our club has a Jet mini mounted on the Jet stand. It works just fine. I have a Jet mini mounted on a portable bench. I countersunk holes in the top of the bench to set the rubber feet of the lathe into just to keep it from walking away. It works fine also.
bill
Pat Taylor
>I'm new, but my Jet mini on the Jet stand feels mighty sturdy, and doesn't do "the walk" until I load up a 9" diam. x 10" tall non-rounded wet blank.
gil jones
>Joe, the spindle center height is 45.5", and I am standing on a .5" thick anti-fatigue pad (which works for me). The bench is all wood (painted gray), a 2" thick top, and weighs about 250 pounds (without the lathe). No extra weight added. The lathe came with padded feet that adjust up/down, and there is one 2.5" deck screw going diagonally through each leveling/support foot and into the bench top. So six deck screws hold the lathe to the bench, and that seems to work well. If it is shaking too much, I slow it down (sure would be nice to have EVS).
Gil
Thank you.
Tom Wilson
>I have mine mounted on one side of a board, a scroll saw is mounted on the other side. I can rotate the board and use either the lathe or the scroll saw (I have a very small shop). the whole thing is on wheels to push out of the way when I am doing something else. I also have to sit down to work, having back problems that won't allow me to stand for very long.
