Long Term Test Results of Storing Anchorseal
Steve Russell
>Hello to the group,
There was a recent question on the turning newsgroup about how long Anchorseal would last in storage. As it turns out, this has been the subject of one of my long term tests. I'm reprinting my reply here, as I'm sure some of the members here may be curious about this as well. Reply follows:
As many of the group here know, I'm always testing things in my studio. It's a character flaw of mine I guess... One of my long term tests has been on the shelf life of finishes and adhesives. In addition, I threw in a few other things at the last minute... Anchorseal was one of the products I added to the primary protocol.
I have tested both the winterized version and standard version's of Anchorseal. The testing has thus far spanned 7 years for the Anchorseal products. All of the product variations have been stored in the original plastic bottles and measured for temperature, color, consistency, viscosity and specific gravity every six months.
In addition, drying time is recorded on sample wood with temperature and humidity recorded. A supplemental test is also performed with heat assisted drying, with the same factors recorded.
Brief summary results thus far...
Winterized Product: No difference in viscosity or specific gravity. No lumps or thickened masses. Drying time in normal range vs. fresh product.
Non-Winterized Product: Test 1A.) Stored inside studio - heated and air conditioned space year round. No difference in measured characteristics. Drying time in normal range.
Non-Winterized Product: Test 1B.) Stored outside, exposed to elements, temperature variations etc. (Stored in original plastic bottle). Product has become very lumpy, with thick masses floating in watery thin liquid. We do not get a lot of freezing temps here, but it happens on occasion. Product experienced a cascading failure of all measured factors and was removed from testing on 1-15-2002.
So, if properly stored the winterized product will last at least seven years. It does need to be stored with a tightly closed lid for best results. Sub-testing was performed on both versions of Anchorseal stored in a temperature controlled environment, with an inert gas layer added in test tubes to establish a boundary layer against normal air contact. Results of this testing have yet to be summarized.
Bottom line is that you should be able to get at least seven years out of any Anchorseal that you purchase, IF it's stored in a controlled environment, with a tight fitting lid to prevent evaporation. I hope this helps you. If you have any questions, please do not hesitate to contact me.
Steve Russell
Eurowood Werks Woodturning Studio
The Woodlands, Texas
Re: Long Term Test Results of Storing Anchorseal
Re: Well Steve, I learned that there is ....
Jamie Donaldson
>... a winter version of Anchorseal? Where does it sell, and what is it called-have obviously not seen it around here!
Steve Russell
>Hello Jamie,
Please accept my apologies - I should have been more clear in my posting... The winterized version is available directly from the manufacturer, but you have to ask for it when you order. I have always purchased my Anchorseal direct, to get a lower price. If it does not say "Winterized" on the label, it's the standard version that will freeze if the temperature gets too low in storage.
I've attached a picture of the front of a 5 gallon container from an article I wrote on using and storing wax emulsions to show you where the "Winterized" text is printed. Basically, they add a small amount of antifreeze to the standard Anchorseal to winterize it... These days, I always order the winterized version because I buy in bulk 55 gallon drums, or 5 gallon pails and I don't want to worry about using it up before winter - just in case I have to store it outside in an unheated storage building. If you have any additional questions, please do not hesitate to contact me. Take care and best wishes to you and yours!
Steve Russell
Using Anchorseal problem
Ron in Drums PA
>At one time, I would pour about 12oz into a clean plastic 32oz jar with a wide mouth. This was also tall enough to hold a brush. I found out that after 6-8 weeks or so the anchorseal would smell sour and look watery.
After this has happen to me three times in a row, I gave this method up and only pour out what I need. Cleaning the brush is a RPITBS (real pain in the back side)
Has anybody else ever have this problem?
Re: Using Anchorseal problem
Gary in Zirconia, NC
>No, I never clean my brush. It lasts 2 or 3 years. What I do is pour 8 or 10 oz. in a plastic snap top container and put the used brush in a ziploc bag. Sometime the brush gets a little stiff if I don't use it for a month or so, but it loosens up with a little use.
Re: Jamie........
Mac
>Check with Pete K. he has the winterized version.I get it from him and it does just fine up here in the COLD NORTH.
gil jones
>Ron, I never clean the brush. I buy 5-gallons (at out turning club for $25, from our 55-gallon drum), and pour a gallon into a 1-gallon plastic jug. In use, I pour "some" out of the gallon jug into a can or jar, and paint it on the end grain as needed. I had the same problem as you with the bad smell and lumpy if I kept small amounts in a jar. The brush is stiff with cured wax emulsion from the last use, but that softens up in way less than 30 seconds, so I see no point in cleaning the brush. The product we use/sell at the turning club is called Sealtite 60 from ISK BIOCIDES, INC., 416 East Brooks Road, Memphis, Tennessee 38109, Ph: 901-344-5350 or 1-800-248-7961.
I have used Anchorseal, and Sealtite 60 seems to be the same, or at least a comparable product.
Gil
A
gil jones
>I forgot to say that I pour what I do not use from the jar, back into the 1-gallon jug (apparently this causes no problems as it always looks the same).
We really do need an editing/correction feature on this forum.
Allen Neighbors
>Steve, I bought 2 5-gallon cans about 2 1/2 years ago. It doesn't say "winterized", but it does say "with Polypropalene Glycol Antifreeze". Mine sits in my shop all year long. I pour it up in a 3# coffee can, and keep the lid on it, with my short-handled brush in it. This year it froze pretty hard. When it thawed it was pretty thin, due to settling in the bottom. I shook the tar out of it, it thickened back like it was, and has stayed that way. It seems like it is still working for me, so far. I think. Maybe...It acts just like it always has. Any ideas on this?
Bill Neddow
>i bought about a 9/10ths full five gallon pail of Anchorseal from another turner who said it should be fine. When I tried to use it, it was full of lumps and thin watery white liquid. I called him about it, and he though it should be fine because it was winterized. Turns out he had had it so long he could not remember when he bought it -- 7 or 8 years. And it had sat out in an unheated back shed in Canada all that time. Seems there is a limit to the number of freeze-thaw cycles it can go through -- though in practical terms, I don't think most people could ever get to that limit before the Anchorseal was used up. I pried the top off, stuck in a big paint mixer on a half-horse drill, stirred the hell out of it, and the lumps went away, never to reform. It seemed to perform as well as the new stuff. Anyway, I did not have any blanks break. Good stuff.
If Lumpy Just Microwave
nathan murphey
>Thats all its takes is to heat it up and melt the lumps. Stir a little and you are ready to go.
Bruce in Saint John,N.B.
>Jamie I clean my brush in warm water, after the heavy is removed I add a shot of dish detergent into the bristles, give it a little workout, rinse with more warm water. Hang it up to dry untill the next time, certainly works for me.
Leo Van Der Loo
Only problem I ever have is it gets thick on me
Leo Van Der Loo
>if I don't close the small can up good or leave it sit for a long time, than I will add some new and stir, and away we go again.
At one time I made a hook so I could hang the brush up in the can, but than I would end up with a stiffened brush, and have to work it to get soft again, so now I leave it just sit in the can, works better for me. I have a heated shop, so I never used the winterized kind, but if they use alcohol as the protector, that will evaporate after a while, don't know if they use that though.
Have fun and take care
Leo Van Der Loo
Steve Russell
>Hello Allen,
I did not mention that I tried various methods for re-emulsifying the frozen Anchorseal when it thawed... Stirring with a paint stirrer mounted in a cordless drill worked pretty good, but the best method was slowly heating and stirring it once it was warm. The resulting product was not exactly like the original, but close enough and it worked on test pieces.
Since I only buy the winterized version now, I'm not too concerned as it usually resides in the studio when it's stored and the studio has year round heat and central a/c. Bottom line is don't throw it out if it freezes, but it's always better if you can prevent it from freezing in the first place. Take care and all the best to you and yours!
Steve Russell
When I say sour
Ron in Drums PA
>When I say sour, I mean the smell is really repugnant. The reason I clean the brush is so I don't transfer anything to a fresh batch.
I wonder if it's possible that I got a bad batch since no one else has had this problem.
Re: When I say sour
Steve Russell
>Hello Ron,
I've never had any Anchorseal go bad as you indicated in your post. I keep a small amount of Anchorseal in a sheetrock mud bucket with a tight fitting lid and just leave a chip brush inside (no cleaning). When I run low in the small bucket, I pour a bit from a five gallon bucket into the smaller one and apply as needed.
Although the Anchorseal in the smaller bucket gets nasty looking at times (sawdust residue, dirt etc), it never has developed a bad smell. The larger five gallon bucket is always kept clean, because I decant small amounts as needed into the smaller bucket.
I'm wondering if something is "growing" in your batch and creating the bad smell? You may have picked up something from the surface of the logs you were sealing, or the ground when you were painting your logs. I would doubt that the original batch was contaminated when it was manufactured, but anything is possible I guess.
If it were me, I pitch the old smelly batch and start fresh... Decant into a smaller bucket when you need to apply the product and keep your original batch clean and fresh. Good luck to you and best wishes in all of your woodturning endeavors!
Steve Russell
