Cold weekend part #2
Dick Hines
>This is a piece of maple that I got after a storm this fall. 6 1/2" X 4 1/2". One coat of Wtaco. Hollowed through the top and then the opening glued back on a turned. Joint covered up with 3 v cuts.
Dick Hines
Re: Cold weekend part #2
Bob Moffett
>When you reversed turned the bottom was the top piece glued in or did you glue it in after the bottom was turned? How did you hold it to reverse turn the bottom? If you glued it in after turning the bottom, how did you line it up so well?
Dick Hines
>Bob, I turned a tenon on both ends of the piece. Then I parted off the top,neck. Before I parted it off I marked a line across the cut. That way I have a refferance line so when I glue the top back on I can line up the grain. It workes for hollowing through the bottom too.
After I have glued the top on I turn it to shape and then at the glue line I use an old skew that I have ground to look like a front of a boat to cut the groves at the glue line.
If I don't forget and sand before I line up the refferance line I can hide the joint so it can't be seen. Most of the time.
Lan Brady
>Dick,
I am not artsy enough to know why, but I like this piece.
It has a shape that is pleasing and makes me look at the grain patterns in the wood.
Thanks, Lan
Dick Hines
>I am not artsy Lan. Mother Nature did the figure in the wood I just knocked the edges off to see what was in there.
