Re: Group of Door Stops
Greg Haugen
>I take a piece 1 1/2" square, make my pommel cuts 2" or so in from each end. Turn the details on each end. Carefully part off both end, tailstock side first-support that end in your hand and part off the headstock side. I measure 5 1/2" diagonally from the top edge of the pommel. I freehand cut the diagonal line on the band saw. Two are basically made at once. I chuck my power sanding mandrel (2" bowl sander) in my talon chuck with my spigot jaws and go from 80-400 grit with the lathe as a power sander and holding the door stop in my hand to sand the flat and diagonal areas. I don't have belt sanders but I can start and finish the sanding in 5-8 minutes with sanding to 400. Finish then is Waterlox. I do put a sheen on the "turning" and steel wool the sheen off of the flats. It's going to get beat up anyways by a door. You want the turning to be the attraction.
These are on the "son of skew" video by Alan Lacer and they have been in Woodturning Design magazine in the last year. It's a great skew project, its one of the only projects I know of with pommels.
Hope that answers your question.
Greg
