Arthritus and turning tools?
John Kyler
>Looking for source for woodturning tool handles for someone with limited used of their hands do to disability etc?
Are there any sources?
thanks again
John
John Kyler
thanks again
John
Re: Arthritus and turning tools?
>John I don't know of any sources for special tool handles for arthitis patients. Perhaps a captured boring bar system like the Lyle Jamieson boring bar or the Elbow Tool. It takes very little hand pressure to work these systems.
If you can't find one... Let me try some ideas
Doug Thompson near Cleveland
Bill Neddow
>A chap named John Pilgrim in the Vancouver area makes some large diameter handles that are really good for people suffering arthritis. I believe he originally made them for this purpose. They are also good for reducing carpal tunnel problems. If you are interested, I will e-mail you his e-mail. You can reach me at bill.neddow@sympatico.ca. Alternatively, you could simply use a ferrule like the ones Oneway sells (or make your own) and turn a handle of an appropriate diameter. All my tool handles now are about 2 inches in diameter -- not because I have arthritis, but because I turn a lot and was getting cramps in my hands. This stopped the cramps.
tm
>I'm turning with impaired hand function...
The idea of a larger diameter tool handle is something I landed on recently too. I had a bash bar that was too painful to push when I wanted to change anything on the tailstock. I turned a large ( maybe 3 inch diameter )oak handle that looks exactly like a lathe tool handle only bigger.
I mounted a drill bit the same size as the bash bar in a morse
taper chuck and bored a hole. I put a few drops of CA glue inside
just for good measure. It works well for me and I've been thinking about trying a handle for one of my backup bowl gouges.
Richard Raffan's instructional DVD called "Turning Wood" also shows how. Rockler has it for about $15.
Another adaptive feature I've been thinking about is a foam coated tool handle for a more cushioned grip...less impact is easier on those screaming carpal tunnels. Not that tool handle dip they have at Home depot, because its too slippery but REAL foam.
Maybe something from a place like this
www.gripworks.com/foam-grips.htm
Eventually I'll have it covering metal levers on the Nova that
lock or release tailstock, turning headstock, banjo & toolrest adjustments. My hands take a pounding daily. Dampening impacts
and contact with cold metal means more quality time at the toolrest.
tm
I forgot to mention
tm
>Something else to keep in mind if you are just getting started is the
height of your spindle in relation to your elbow.
Too low or too high can cause problems.
Its important to your arms & shoulders if you want pain free turning.
Better brains here can give you specifics in a new thread.
Good luck,
tm
Peter Charles Fagg (UK)
>I have the beginnings of arthritis in my right hand and to alleviate some of the agonies I have made all my own handles. They are far too large for others but I can fit my hands comfortably to the size.
Now if I could turn something for my painful knees!!!
Regards, Peter.
georgetroy
>I too have arthritis in my hands and right hip. I use Oneway and John Jordan handles. After shaping on the outside I will go to my outrigger tools by BCT from Packard and Basham scrapers with fixed outriggers to remove wood on the inside. My arthritis in the hands has actually improved from the Woodcarving I now also do. I started Woodcarving in September after a 7 year lapse and I judge the improvement in the hands has been approximately 50%. I no longer have the locking of my hands after making a cut and the pain is almost gone now. I guess use it or lose it. GT
Great question, John...
Brad Vietje
>In addition to the larger handles many have suggested, some people might benefit from differently shaped handles, or tools that mount in an Armbrace for some functions. In addition to larger diameter handles, making some with 6 or 8 flat sides might be useful. There are also some good home-made outriggers or some sort of short handle mounted at a right-angle, like on many drills (see pic).
Robert Chapman, in his book Woodturning: A Fresh Approach, shows hollowing tools with side handles, and these should be very helpful for those who can't grip a long cylindrical handle.
Hope this is helpful -- sorry, I couldn't find a turning tool with the side handle.
Safe spinning,
Brad Vietje
Newbury, VT
here you go *LINK*
Bob Fawcett
side handle
