We value your privacy.
I have been dabbling with some lacquer finishes. I tried automotive and found it is not your father's lacquer. The new chemistry is totally different than it was when I was a lot younger. It takes a lot longer to dry and is quite expensive. I also tried a spray can that I got from Lowe's. I thought it did a decent job but I have no idea what the chemical make-up is. It dried relatively fast and did decent job. I am assuming it is what is called furniture lacquer.
My question is, if you use lacquer, do you prefer automotive or furniture type and why?
>I've shot lacquer for years, using nitrocellulose lacquer. They've quit selling it at the lumberyard here in my town, so I buy pre-catalyzed, water white (clear), hi-build lacquer at Munger's in Oklahoma City (when I go there to visit my son). I buy it by the gallon, a couple at a time.
I have an old Buffalo spray gun (cheapie) that I've used exclusively for lacquer, thus, I almost never have to clean it. I leave lacquer in the cup 24/7. When I want to spray something, I grab the gun, connect the airline, and pull the trigger while rubbing my finger across the nozzle. Lacquer melts lacquer, that's why I don't have to clean it after every use, like I would a paint gun. Occasionally, the lacquer builds up on the nozzle a little too much, so I take the spray nozzle off the gun and drop it in a jar of lacquer thinner overnight.
They say there's no need to thin pre-cat lacquer, but I do... about 20-25% thinner... and I add about 3/4 of a film cannister of Retarder to each cup, just before I add the thinner. The Retarder delays the drying time so it will flow out a little, to allow for my shaky spraying technique. I almost never get a run.
After all that... to answer your question: I guess what I get is a furniture lacquer, and I use it because it works for me. :o)
>Don't make spray lacquer finishing too difficult. It's actually fairly simple and easy. I have used Sherwin-Williams and Porters Semi-Gloss. It comes in a gallon can. There is also a sanding sealer which I recommend as a first coat. Spray on a coat of sanding sealer. Allow to dry. Sand out the nibs and dust with 320 or 400 grit wet or dry paper. Spray on a couple of coats of topcoat and you're done. I always thin lacquer and sealer 10% or so. I use an old Binks No. 7 gun, which I clean after every use.
If you really want to keep it simple, buy a spray can of Deft at Lowes. It comes in Satin, Semi-gloss and Gloss. I prefer Semi-gloss. Spray on a coat. Allow to dry. Sand out the nibs and dust and repeat. No sealer necessary. About three coats is sufficient. Deft is usually dry to the touch in thirty minutes and is sandable in an hour or so, depending on temperature and weather conditions. The spray cans really have a pretty decent spray nozzle and lay down a really smooth finish. How's that for simple? No spray gun to clean. No thinning with lacquer thinner. No retarder to add.
>I use Deft gloss in the spray can. I like the gloss because it gives a more clear finish. If I want a semi or satin finish I just rub it out. The spray nozzle is very good. It is not your typical nozzle that you find on most spray cans. I used to use an HVLP system to spray, but found it to be to much for what I needed. After I get the finish that I want I rub it out and buff. Pretty simple.
>Thanks all. I am really into easy. My local Lowes no longer carries Deft products but I will look around. The one I used today from Lowes doesn't seem to have a very good nozzle. It left the finish with more orange peel than I like and the mist was not real fine. Thanks again.
Your comment about "Pulling the trigger while rubbing my finger across the nozzle" scares me a bit. We shoot lacquer on cabinet installs and caution everyone to avoid contact with the tip of the gun as well as check the air lines for leaks. A shot from the gun or grasping a leak in the hose can cause a penetration under the skin that can lead to a fatal embolism. I cannot tell you what it is like racing someone to the hospital after this type of accident.
Perhaps you meant something else or you are not running your gun under pressure, but an inexperienced user that reads that sentence and does what you mentioned, could be putting themselves at risk.
>the skin on my finger. I've done it for years. My airline is cut down to less than 100 PSI when it enters my spray room. Then I have an adjustment valve and guage at the handle of my gun. When I connect the airline, I adjust the pressure to 29-31 lbs. Safe enough for this old man. :o)
For lacquer, we try not to exceed 40 PSI based on conditions. All the jobs are done on-site.
We have two real concerns, such as leaks in the line before it reaches the gun and when someone who was doing an external paint application (requiring more pressure to penetrate the siding) uses the equipment and does not reset everything. Doesn't happen often, but in some instances, when the job requires both internal and external (and with everyone spraying production paint inside no days) guns have a way of getting mixed up.
My big concern was that there was no mention made of air pressure and a novice might not be educated enough to know or even consider the potential dangers.
>Bill, you may want to try musical instrument lacquer, available from Stewart-MacDonald. It's designed to flex with wood movement. Spraying lacquer is easy, but expect to spend AT LEAST as much time as it took to turn a piece OR MORE to do a prefessional lacquer finish. For one of my lacquer finishes, I apply up to twenty coats, wet-sanded to 2500 grit between coats. Solvent based lacquers are becoming a thing of the past, due to environmental concerns.
