New Jet Mini Lathe *LINK*
Tommy Holmes
>Jet has their new mini lathe for sale on Amazon for $199.99. They have added indexing and arbor locks. Could not find this new lathe any place else. Sounds like a good price if you are looking for one.....or not looking for one and get it anyway:)
Jet - JML-1014I:10"X14"Indexing Mini Lathe
From the Manufacturer
This New JET Mini-Lathe replaces the popular JML-1014. Without changing the basic reliable lathe, Jet has added arbor locks and indexing. This lathe is a powerful cast iron machine for smaller projects. The headstock is driven by a 1/2 HP motor with six speed selections to choose from and comes with several accessories included that are optional on other machines. This model is also machined on the tailstock end to accept the JET 20-inch bed extention that is available. The Mini Lathe stand #708354 and the bed extension #708355 will still fit this new Mini-Lathe.
Amazon - Jet Mini Lathe
Re: New Jet Mini Lathe *LINK*
John Kyler
>I think you will find that Jet has the 1014 on sale for $199 at all dealers.
And the new 1220 is $299.
John
Tommy Holmes
>A 1220 sounds like it could be a nice addition. I had heard they were going to be making one and had looked around but didn't find anything.
Nelson
>Woodcraft has them also, same price.
eaglesc
>After clicking the supplied link I noted the lathe is described as an"indexing lathe"
Unless I am mistaken, this is something new.
I understood the larger new one coming out would have the indexing feature, but the 10- 14 I have does not.
>I agree. I have never seen a jet mini with indexing, except the two that I am working on. I've added indexing to them.
Looks just like mine and it has no indexing.
Don Henthorn
>I don't see any evidence of an indexing mechanism in the picture.
Forgive my ignorance, but..
Pat Taylor
>What is indexing, in the context of a lathe?
Thanks,
pat
Re: Forgive my ignorance, but..
wilbur
>Indexing on a lathe involves evenly spaced holes, usually on a wheel attached to the spindle, with an index pin that inserts into the holes. A common set up is to have 24 evenly spaced holes on the wheel. With this device, you can take your piece while it is still on the lathe and lock it into position, usually to add decoration.
This way you could, for example, add 8 evenly spaced flutes to a spindle that you are turning. You would lock the spindle in place with the indexing pin, make your flute down the length of the spindle, unlock the indexing pin, and rotate it to the next position, lock it in place, add the flute, and so on.
The reason 24 is a common number is that you can use this to do spacing for 2, 3, 4, 6, 8, 12, or 24 decorative items. Of course, there are indexing wheels with more or less holes.
Got it! Thanks.
Pat Taylor
Re: Looks just like mine and it has no indexing.
Nelson
>The indexing pin is a spring loaded pin you screw in and is located on the handwheel side and is not visibale in the photo, it has 24 indexing holes.
