Advice for making a number of identical bowls
Charles R. Smith
>Can you offer some hints or tips to a fairly novice turner who wants to turn a dozen bowls for his daughter. I'm not certain how to make them all exactly identical. (Perhaps the word 'exactly' is redundant when used with 'identical'.)
The configuration or shape is rather simple (6 3/4 in diameter, 2 1/4 inch deep), to match her china pattern. I was going to make a template using a tracing profile gauge (i.e. Lee Valley part 44K14.02) I have a supply of wet wood and so was going to rough turn them prior to drying and final turning. I was thinkinng of making a prototype series in London plane, and then doing the definitive series in either cherry or plum (since those are the woods I have, and they were free!). Comments or suggestions? Thanks so much!
Charles in Victoria (who hasn't turned on his table saw since buying a used General 160 a few months ago)
Re: Advice for making a number of identical bowls
Roger T
>Good morning,
I believe you are on the right track. I have seen an article somewhere about a man that made a set of collection platters for his church. He had made both inside and outside cardboard patterns for this work.
Dont forget to make 3 or 4 extra roughouts just in case one of them goes bad.
Hope this helps,
Roger
>That's what I did. The cardboard templates that is. I did write an article on making a textured collection platter for American Woodturner but I doubt that is the article your talking about. They were walnut with 3 maple inserts in the rim. Back then my skills weren't as good as they are now.
I made cardboard templates and made the pieces as close as I could get to those shapes. I turned more platters than needed and then picked the ones that matched the best to send to them. That was being a little too picky as they all were extremely close.
With templates and light cuts you should be able to get them to match close enough that most people won't be able to tell. There's nothing like doing multiple matched pieces to improve your skill. It's a good experience.
Bob Fawcett
>I have to agree with John. The first project I did after getting my lathe was to make a set of bedposts for a 4 poster bed for my wife. It scared me to death at the start, and for several months I had 1 bedpost. Finally I just bit the bullet and started turning matching posts. I surprised myself. My advise, just do it!
The templates are a great idea too, I made a story stick for my posts.
Claudia Hayward
>Hi Charles
Sounds like you are doing a lot of practicing with your turning! The cardboard template is a good idea. So is roughing out more bowls than you need. Given you are working with cherry or plum I would suggest boiling them though, that should cut down on the cracking. Get one of those blue canning pots and a propane camp stove. After you have roughed out the bowls, put them in the pot and cover them with cold water. Do this the same day that they are roughed out. Obviously you will need to do this several times since you will only be able to do 2-3 bowls at one go. Bring them to a boil, boil covered for about an hour and a half then turn off the heat. Leave them till next day. Remove from the water and set aside to dry. You don't need to end seal them after this process, you will just encourage mould to grow. OH yes, and do the boiling outside. It's a little smelly!
Good luck.
Claudia Hayward
Make Templates
Jorge Castaneda
>Both for the outside and the inside.
Personally I prefer each to have its own personality...
$0.02
Jorge
