Photo help
Photo help
Photo help
Bob Fawcett
>I built my version of Jamie's phrugal photo booth and took this picture this morning.
What do I need to do to improve my photo?
My camera is an older Canon G2. I set the white balance to tungsten and mode to macro. I have slightly adjusted this in MS photo (the free one that comes with Windows). The background is white. I think the white balance is wrong, but I am not sure how to correct it.
Re: Photo help
Re: Photo help
Gary in Zirconia, NC
>What are you using for lights?
Re: Photo help
Re: Photo help
Bob Fawcett
>quartz shop light. aimed at the top of the booth to the left of the object.
Re: Photo help
Re: Photo help
Bob Fawcett
>Here is one with the flash and it is a lot closer to the right colors.
Re: Photo help
Re: Photo help
Ken Grunke from SW WI
>Bob, check your white balance setting again. Looks like it's set to daylight.
BTW, I have exactly the same camera, the Canon G2. Very nice unit for an older camera. If you have an AC adapter for this, and have no need for it, I do!
Re: Photo help
Re: Photo help
Bob Fawcett
>Wish I had a spare Ken.
I think I found the issue. I was pushing buttons in the right sequence.
Hope this is better.
When I preview this, the picture doesn't look as good as it does in MS Photo. Is the same picture. What gives?
Re: Photo help
Re: The color balance is obviously .....
Jamie Donaldson
>... not correct- does the camera have a setting for incandescent as well as tungsten, or a custom white balance setting? It also appears that the turning it too far forward of the light source, and another light was shining directly on the turning. Play with the color balance and try again.
Re: Photo help
Jamie Donaldson
>... better! That was fast! Now the light is too far to the back- the shadow should be toward the back rather than the front- that's why the front of the turning is shadowed.
Re: Photo help
Another try
Bob Fawcett
>Another try.
It still looks like it looses something in posting.
Maybe it still needs a little something.
Thanks for all the help.
Re: Photo help
Re: Now you're cookin'! Can you ....
Jamie Donaldson
>.....move the light further to the front, and move the background further back to reduce the light intensity on the background?
Re: Photo help
Re: Photo help
>Could be that the browser renders colors a bit differently than your image program. The browser is basically the final word here, so I always view an image with it to check the final image quality.
I've heard of people having trouble with the preview button when posting an image on WoodCentral, so I avoid using that. Instead, I open the image directly in my browser (Firefox for me) by right-clicking on the image file and choosing "Open with". I have it set to open in a new tab. Not sure if Windows has that option, I'm using Linux. Or in your browser, under the File menu, choose "Open" and navigate to the image.
Re: Photo help
Forgot to mention...
>You've got the color balance fixed, that looks great now just follow Master Donaldson's advice ;))
Re: Photo help
>Bob YOur getting there. I find that I have to boost the contrast in my photo software to make it look decent on the WC. It looks fine on my monitor but when I push the Save As button which lowers it to 72 dpi it looks really flat, kind of like your last photo. If I boost the contrast so it actually looks a little harsh on my screen then it looks fine on WC.
I also believe you are a litte underexposed. Try using the over/under exposure button to overexpose by 1/3 or 2/3 rds. This should be on your camera somewhere. This works well on white backgrounds especially when you have that much white showing.
Re: Photo help
One more
Bob Fawcett
>Trying to incorporate the advice from the photo pros.
Re: Photo help
Should I try to find another background?
Bob Fawcett
Re: Photo help
Thanks for posting
Troy German
>What a great exercise for many of us to see. Thank you Bob for walking though this for all to learn from, and thank you to those who posted with advice.
With much to learn,
Troy
Re: Photo help
Re: Thanks for posting
Bob Fawcett
>I am glad others got something out of this, but all the thanks go to our resident photo experts who are so willing to help.
Re: Photo help
Re: I had to take a break to .....
Jamie Donaldson
>... watch the finish of the Univ. of KY. ball game! OK, where were we? How do you like the progress so far? I should have mentioned that I set the exposure compensation on my Olympus at +1 for all work with a white background. Your last posted image is looking pretty good, but the background could be somewhat darker to enhance the appearance of depth- that's why I asked if you could move it further away from the light..
Re: Photo help
Bob Fawcett
>Its currently as far as I can move it with the setup I have. Should I look for a darker background?
I set the exposure to +1, but at this point I am not certain that that is true for the last image. I couldn't see much difference. I also bumped up the contrast like John suggested. The last thing I did was to experiment with how much compression to use to get as close to the 40K limit for WC as possible. That helps with the fuzzy edges I was seeing.
Re: Photo help
Re: Should I try to find another background?
>Bob You don't need a new background unless you just want one. The fade backgrounds you can get from www.porters.com look really nice but they are painted and scratch easily so you have to really be careful with them.
Camera meters only know an average gray so everytime you fill the frame with something other than gray you will often need to make a small adjustment to the exposure. For example if you took two photos on your white background, one with a big walnut piece and one with a big holly piece, your camera would try to take two different exposures. However in this example you didn't change any of your lights so the exposure would be exactly the same. If you used manual settings nothing would change and you would be OK but if you use any type of auto exposure then the camera will change things. That's why they put the over/under exposure compensation dials on cameras.
Re: Photo help
camera mode?
Mike Nelson
>Bob, what mode are you set on? I can get a photo like your previous one but loose the sharpness and clarity of the grain. With a flash, I get good sharpness but also the shadow, glare etc. What to do?
Re: Photo help
Re: camera mode?
>Mike Flash is a small light so it gives hard shadows. Large lights like open sky gives very soft shadows but won't show fine details because the shadows are so soft.
What we try to do with the photo booths is to create sort of an open sky look. However if you make your lights too even then you lose the shadows and consequently it doesn't look as sharp. sometimes I use a weak light that is direct and not shining through the panels or bouncing off the panels. This small weak light creates a little shadow on everything. This is kind of like using flash off camera.
Re: Photo help
>Bob, the most versatile backdrop is white, if you can control the intensity of light at various areas of the backdrop. If it's big enough (ideally, 4 ft wide and 8 ft long or more for any turning under 12" either dimension) you can lie it flat, and through strategic placement of lights and baffles, have a very nice gradiated backdrop starting at white in the foreground and pure black at the top of the image.
Then you can get creative with point lighting behind the subject, for a halo effect if desired.
Re: Photo help
Re: Mike- if your camera has an...
Jamie Donaldson
>... aperture priority mode learn to use it to achieve control of maximum depth of field. Remember that a focus point 1/3 from the front and 2/3 from the back of an object like a bowl will yield max. DOF, a setting you can't control with AUTO focus.
Re: Photo help
Bob Fawcett
>Jamie,
I have AE and manual modes on the camera. I tried AE early on and locked the camera on F8. As I was still having other problems, I went back to P mode on the camera. P mode on a Canon is Program AE. It is an auto setting, but lets you use exposure compensation and white balance. You can also select several sets of shutter and aperture combinations that are equivalent. You probably know all this, but maybe not.
Anyway, while experimenting, I stumbled onto the exposure bracketing setting. I tried -2 0 +2 and I like the results of the the +2. Tommorrow I will take some more shots and play with exposure greater than +1 to see if it gets better. I may also add another small extra light on the right side as it looks to me like I may not have quite as much on the right.
