THE WOODRAT IS BACK!
Kingwood box...
Kingwood box...
Mike Stafford
Kingwood box...
Mike Stafford
>Here is a little box turned from kingwood I received from my wife for Christmas. It finished up at 2 1/4" in both height and diameter. Sanded with wax as a lubricant to 12000, then cleaned with mineral spirits and waxed and buffed. I have found this to be about as good a way to finish oily woods as I have stumbled upon.
I would appreciate any comments or suggestions on the turning or on how to finish these oily woods. Thanks for looking....
Re: Kingwood box...
Re: Kingwood box...
Don O.
>Spectacular Mike, as usual. That finish looks as good as it can get. Seems like your process works just fine.
Re: Kingwood box...
Re: Kingwood box...
Allen Neighbors
>What he said... Spectacular! Your technique did the trick. And I especially like the inset convex feature on the top of the lid.
I've never sanded with wax as the medium... what kind of wax?? (Disregard the question, if you named it in your post; I'll go back and read it again.) :o)
Re: Kingwood box...
Mike Stafford
Re: Kingwood box...
Mike Stafford
>Allen, just a little paste wax. I initially started using it on end grain so the wood would not get so hot while sanding causing heat checks. Then I found that when I tried to remove the residue it was nearly impossible to remove. The more I rubbed the shinier the end grain became. So now I do it on purpose on the oily woods, cocobolo, verawood, kingwood, tulipwood, bocote.... It is important to sand the wood very finely as any scratches show up even better with the wax.
Thank you gentlemen for the comments...
Re: Kingwood box...
Re: Thank you, Mike, I'm
Allen Neighbors
>pretty sure that I'm not the only one who has learned something from this. Thanks for posting!
