hollowing smooth
hollowing smooth
hollowing smooth
dwfII
>I've been working on an eight inch hollowform for some time now. I've done several others with the Sorby Hollowmaster (?) and very sucessfully, too.
But now I have this piece of dry, Siberian (?)Elm and I want to hollow it out through a one inch hole. I've been using the Keltons (?) and removing the wood satisfactorily. I'm now at the stage where I want to start smoothing out the inside as best as I can. But, dern it's rough in there! There must be as much as a quarter to three-eighths inch variation in depth inside the vessel--ridges and valley--all through the pot.
I can't feel these irregularities when the vessel is turning. Is it possible to develop a sense of the inside through the tip of the tool? Is there some advice someone...anyone...can give me that will ease this operation a bit ahd allow me to get through this without punching through the side?
thanks
DW
In the High Desert of Central Oregon
Re: hollowing smooth
Re: hollowing smooth *LINK*
joaz
>I am only familiar with the tear drop scraper for final shaping so my advice may not work here if thats not what your using.
But if you are, turn off the lathe and run the scraper down the side so you can feel the "hills and valley's". Close your eyes and really imagaine what going on in there. Now turn on the lathe at a slow speed and and scrape the tops off the hills. Take your time. It might help to have a small mag lite to see inside as you go.
Try to get it as smooth as you can, especially as far down as your big finger can reach. Good luck.
joaz
http://www.maine-web.com/woodturning
Carole Valentine
>Yes, you will learn to feel them. As Joaz said start with the lathe off and try to feel them with the tool. Note the location of the biggest ridges based on how far in the tool is. Have your tool sharp and take very, very light steady cuts so you keep paring down the ridges. If you take aggressive cuts and let the tool move in and out in relation to the vessel wall, it just follows the the hills and valleys and not much is accomplished. At least that's what I have discovered.
Bill Hale
>I agree with allthat joaz said except the slow speed. I am a high speed turner and feel I can get a better cut with high speed and very light touch. Sharp tool, high speed and light touch and you must keep the inside clear of shavings.
Joaz-- My wife still has the bowl I made from your wood. Thanks again.
Good turning and be safe
Bill in Show Low AZ.
Allen Neighbors
>I agree with all the above. Turn the lathe off. Put the tool in, and feel the ridges (I do this with my 3/16 cutter). Use a sharpie to mark the first ridge and the last on the shaft of the tool, so you'll know how deep in they are. Then install the teardrop scraper, turn the lathe on slow, and make a pass or two, using the shaft markings, to guage how deep you are cutting. Keep checking with a light, and clearing out the shavings after every couple of passes. When you've got it pretty well smooth, then speed up the RPM and make your final passes very lightly, with a resharpened tool.
You'll get to the point that you can feel them as you are hollowing.
HTH.
Allen,
in 22 degree, snow-covered Childress, TX
robo hippy
>I also have the McNaughton hollowing tools. I like them for the roughing work, and a tear drop Sorby for the finishing cuts. A laser pointer helps a lot to get the walls consistant rather than calipers. It is also a lot faster. Once you have desired wall thickness, then bring out the tear drop for clean up. Use a very light cut. This is a 'touchy feely' thing. It will take somp practice to be able to feel how smooth the inside is. If you don't have a pointer, then calipers and a flashlight (mini mag type that can focus the light) to see inside works.
robo hippy
Jorge Castaneda
>dwfII,
Put a light to the inside of the vessel and see where you have thin or thick. mark or kepp a record and go to it slow with fine cuts.
Good luck
Jorge
ps, do not leve the light too long in thre, the heat can make cracks. DAMHIKIT
Paul Porter
Good idea Allen! I learn somthun nu...
Paul Porter
>...here every day. I never thought of marking the tool...I guess I've focusing on the laser to long.
Wally Dickerman in Arizona
>Hi DW...There is a tool that every hollow form turner should have. It's a flexible tool light. You can find it on page 21 in the Craft Supplies catalog. It enables you to really see inside of the vessel to see what you are doing. They suggest that it be used while fastened to a tool, but that won't work with a small opening.
You've had some good advice so far. I suggest that when hollowing a vessel, you work your way down from the rim a bit at a time, alternately using your hollowing tool and following up with the teardrop scraper to smooth it out as you go. Once you've turned the walls thin near the bottom, it's difficult to come back and work on the area near the top.
Wally
Brad Vietje
I do what Allan does and...
Brad Vietje
>I try to add a shear angle in two ways with hand-held tools:
1. I use the cutting tip above center somewhat, and rotate the tool CCW -- probably about 15 - 20 degrees.
2. I lower the rest, and lower the handle so the cutting tip is well above center, and as above, rotate CCW for more shearing angle, if needed. Laser guided hollowing has a lot of people working AT center, where the laser measurement works best, but there's no reason you can't hollow well above center if you're using calipers to measure.
Elm is pretty stringy, so light passes with very sharp tools will help a lot. I usually smooth up the insides (from top down, as Wally suggests) with a 3/8" bullet shaped Sorby cutter on a curved or swan-neck tool; for larger openings I use the Stewart teardrop scraper on the curved tool held in an Armbrace handle.
Safe hollowing,
Brad Vietje
Newbury, VT (where its above freezing today (!) but headed to -15 or so this weekend)
dwfII
>Thanks to all for the good advice. My problem is that the hole in the vessel is about one inch wide and I don't think I can get my Sorby in there. I certainly cannot jimmy it around to shear srcap under the shoulder of the HF. I guess I'm limited to the Keltons.
But take the point--light cuts and ample exploration, visually, of the terrain inside before proceeding.
Thanks again...if ( barring break-throughs or catastrophic catches) and when I get it done, I'll post it.
DW
dtewell
>I would love to give you some expert advice, but I made my last HF bigger on the inside than on the outide. So I'm sure you don't want any advice from me. Good luck.
Re: DW-the Sorby tool we have mentioned is the ...
Jamie Donaldson
>swan necked scraper holder that is used in the Stewart/Sorby handle. It is my preferred smoooooothing weapon with the small teardrop bit, and will go through any hole that the Keltons will. There is a learning curve, but everything related to hollowing takes practice. Make yourself some Ellsworth style wire calipers, and you can forget about the laser toys!
Carole Valentine
>Wally, you are right as usual. I have been using one of those for about 6 months and couldn't live without it. Today I found a little gidget that is a fiber-optic tube about 8" long and about 1/8" in diameter that fits over a mini-mag light. I have not tried it yet because I need batteries for my light, but if it works, it will be great for very small openings in minis where even the tube of the flexible lights blocks your view. Of course there are those who will say "If the opening is that small, why bother!" :))
robo hippy
>DW,
If you ever come over to Eugene, look me up.
robo hippy
dwfII
>robo,
How do I get in touch with you?
