sea urchin ornaments question ???
Ed Moore
>I have been having fun lately making Christmas ornaments using sea urchin shells. The shells come from the Phillipines and have a small sticker on them saying so. When you remove the sticker a shiny patch of glue is left on the shell. I contacted Sea Shell World and asked them how to remove the glue and they said to use WD-40. I have tried and could not see any effect that WD-40 had on the glue. I rubbed the area with WD-40 on a small piece of tee shirt and got nothing.
My question: What solvent should one use to remove the glue on the sea urchins? I recognize that these shells are delicate and would be adversely affected by most chemicals.
TIA,
Ed
Re: sea urchin ornaments question ???
tm
>Home depot has an all purpose solvent called Goo Gone.
Orange Oil is another that works on some adhesives.
Theres also rubbing alcohol and vegetable oil. I have no idea how these will affect finishing if you are planning on coating the urchin tests with something.
Acids like vinegar will disolve calcium carbonate and should be avoided.
Ed Kelle
>I have some cleaners for getting stickers and such off that are citrus based. At least it is organic so might not harm it. Other than that how about just warm water soaking
Paint thinner
Norm Smith in Nova Scotia
Ed Moore
>I just tried hand soap, a little warm water and had some success when elbow grease was applied cautiously in the form of a fingernail brush. Maybe a little soaking first would help.
Thanks, all,
Ed
Ed Moore
>I soaked several shells in warm water for 5 to 10 minutes and the glue did soften so that the fingernail brush would remove it fairly easily.
However,... I think the glue is also used as a wash to sort of seal any cracks. I had a beautiful sputnik sea urchin that collapsed in my hand when I removed it from the water and was about to scrub the glue spot. Aaaaarrrggghhh! Mutter, mutter, ...
Ed
Randy Privett in IN.
>Ed try Naptha, plain old lighter fluid. It will loosen the glue so you can take it right off.
Jerry Whitaker
>I agree, ighter fluid would be my first choice. I use it to remove the sticky stuff off everything and have never had a problem with it on any type of surface.
Really dilute white glue???
Ed Moore
>Naphtha or lighter fluid may well work. I am strongly suspicious that the entire shell has been dipped in a dilute solution of white glue, such as Elmer's. If that is correct then vinegar would dissolve the glue AND THE SHELL.
I may try and reconstruct the one sputnik sea urchin shell that disintegrated. Hopefully I have all the pieces. I'll use some CA glue and see how it goes.
Thanks,
Ed
Jennifer@Indy.USA
>Can you switch to a Star Fish?
Kidding!
Hope you get it all figured out Ed. Sounds frustrating.
Bill Noce
>I have used finger polish remover and a Qtip with some luck in removing the glue.....it softens the glue so it can be scraped off with a small craft knife.
Brent at Robust
>Ed, I have never seen anything turned from a sea urchin. (not to many of these in Wisconsin....) Could you post a picture of a turned and un-turned sea urchin?
Thanks, Brent
Ric Taylor
Denatured Alcohol
Ric Taylor
>It will easily dissolve the sticky adhesives of the type on labels and stickers. If that doesn't work, mineral spirits probably will.
Those are both my "clean up sticky residue" tools of choice.
Ric
Ed Moore
>Hi Brent,
Maybe Bill Noce can post a picture of one of his ornaments. The sea urchin shell simply takes the place of the ball or globe that we often turn. In this case we simply turn the finial and the icicle. I'll see what I can do about a picture.
Ed
Leo Van Der Loo
Brent have alook in the WC ornament gallery
Leo Van Der Loo
Leo Van Der Loo
Brent have alook in the WC ornament gallery.
Leo Van Der Loo
Ed Moore
>Bill,
If fingernail polish softens the glue, shouldn't acetone also soften it? I soaked a few shells in warm water for five to ten minutes and then used the fingernail brush on the glue spot. The results were interesting. One sputnik shell collapsed in my hand and others showed signs of a light coating of the glue all over them. I hope I have not exposed the shells so that they deteriorate faster than normal. Have I removed the "bloom" from the egg?
Please consider posting a picture of one of your ornaments here. I haven't set up my photo box lately and have no pictures of mine.
Thanks, Ed
Bill Noce
>Ed.....
I Have a digital camera which takes good pictures of my turnings but I still have a Fred Flintstone Computer thats about 7 years old...someday I might come into the space age so I would be able to put pictures on line.....
